Why is the APM Power Module limited to only 60A with the Pixhawk/PX4, where it gives up to 90A on a APM?
What is the Output format for the Voltage and Current. PWM? or actual voltage?
What is the output range.
What I want is to modify the Power Module to measure up to 150A.
I had been contemplating putting a low resistance shunt in parallel with the present sensor resistor.
Then I was stumped by the spec limiting the reading to 60A on Pixhawk as opposed to 90 on APM.
I thought it would be as simple as putting a shunt and changing the Amp_per_volt parameter.
