Power connector for 150 kg payload drone
can you suggest 800 rated amps connector and 24s voltage
Maybe something like this
Though I would try to go with higher voltage like in electric cars.
but it used for three phase lines
And? Nothing stops you from getting two of those chonkers and using them for your battery. Though I would try to go for higher voltage because you would be able to save significant amount of weight in copper at higher voltage.
Welding cable connectors maybe but I don’t know about 800a capacity.
can you share some photos
