Power Connect cable burning
I am facing an issue where the power connector cable from the Radiolink Crossflight to the official power module, given is smoking, and the ground wire is completely melted. I have used two wires, and the same issue has persisted. It is a hexacopter, using a 3S 5200 mAh battery, a SE100 GPS, and PPM communication. While I was flying, this happened, and there was no issue in the drone flying; it was stable. As soon as I saw the smoke, I landed it. I have attached the log files for the flight. There was no change in motor performance, and all the ESCs are working perfectly. Before this, I had faced an issue where my Radiolink Pixhawk-based drone kept flipping randomly during flight. Logs showed that there was an issue with the power supply. But even with two batteries, one dedicated to the fc, and one for the motor side, it still persisted. The power module was also replaced twice. Hence, I came to the conclusion that the FC was faulty. Please let me know your suggestions.
Thanks.
49 12-08-2026 17-18-46.bin (779.2 KB)
To clarify, the logs I have uploaded are from the recent issue. I mentioned the previous one to understand whether it was the same fault causing both. I am using the F550 frame with a built-in PDB connected to the ESCs and the Radiolink Power module. The ESCs have not been soldered onto the pads provided by Radiolink.
Radiolink Crossflight is not supported. See Warning#2 Radiolink Unsupported
Thanks for the reply. I’m aware of the Crossflight unsupported warning. However, I’m using the Mission Planner version recommended by Radiolink for the Crossflight, and this setup has been used successfully by me before.
My main concern here is the physical power issue.
I don’t know what you mean by “Mission Planner version” but I don’t see how that changes anything.
Can you show all your cable plan and wiring.
Without detailed cable planing or schematics we can only speculate and guess.
But one thing is already certain: mission planner does not cause cables to burn. Wrong connections do.
Do you have a photo of your setup? a cause can be the spark cap bridging the hot and ground wire making a nasty short, at times made by the heat shrink squeezing the wires of the cap.
I too had the same issue and the setup was identical to yours, from my understanding it’s a hardware level design issue or something as like the ports on the fc was not able to deliver sufficient power for the gps and rc, it was like its capability degraded over time and if you keep tinkering with the fc rather than replacing it, there’s a high chance it would take your SE100 gps with it like in my case it’s a good gps to lose
So it’s better to replace the fc as it is damaged than losing everything else with it
Thank you
I have removed the positive red cable for each ESC connecting to the output port
I meant that I use Radiolink Mission Planner as instructed here, but I don’t think the cable burning has anything to do with the MP.
Best to rebuild this connections as seen in the gray box. looks like a cold joint. Also you need to use one black wire and one red wire for good etiquette. More heat is needed and a bit of flux. overall the connections should be made as one joint, this can be done by twisting a small wire around the two wires of contact then welded.
That craft is a big mess. You must have missed the Hardware To Avoid post
How are the ESCs connected to the battery. Out of the photos I am not able to reproduce your cable plan.
Please write down exactly which wire is connected where.
And for your joints follow the good advice of @Quadzilla
Did you do this before or after you had the problem with the hot ground wire?
I know from past experience having multiple BECs in parallel can cause problems. As you likely know, you don’t want multiple voltage regulators connected in parallel unless they are expressly designed to work that way.
Thanks for adding photos. It’s a lot easier to see what’s going on.
I did it before, while building itself.
Here are the exact connections of my entire drone
1.PDB of the Frame:
-> ESCS, Power module, and Battery (3S 5200 mAh) soldered
2. Crossflight OUT:
ESCs cable connected - power cable removed
3. RC IN and Buzzer - RX cable of receiver and Buzzer cable
4. Power Port of FC - Power cable from Power module
5. All motors connected to ESCs, with standard 3-bullet-hole pins
5. GPS:
-> RX - TX
→ TX - RX
→ VCC TO 5V
→ GND - GND
→ SCL - SCL
→ SDA - SDA
Thank you for helping me with this.
How was exactly your ESCs connected to the PDM
The cable was burned due to high current. This could be either a short cut or the current flow through a wrong cable. I assume your ground wiring wasn’t as needed. So some motor current goes a wrong way.
So again show exactly how your ESCs was connected to the PDB and the battery.
the ESCs have been soldered onto this frame, this is the PDB, current flows through this frame, and is supplied by the battery.
