Potential thrust loss, could it be because of Li-Ion battery?
Hey!
I tried to play with the copter payload and suddenly received this error.
I am using Chinese noname 5010 750kv motors with 40A ESC and 1355 props. Full weight is ~2.5 kg. I guess it must be okay for these motors.
But my batteries are Li-Ion, based on 18650 elements(first is 3S2P LG HE4 5ah, second is 3S3P LG HG2L 9ah)
I attached logs for it. I checked that RCOUs for motors are very different, but the payload was not really centered. Also, I don’t know how to interpret voltage, it seems that it drops very fast but I don’t know the normal behavior for it.
First battery logs - https://drive.google.com/file/d/1EgfJ_nMZYhA-Qzscq_x2UhG2HNPccl8t/view?usp=share_link
Second battery logs - https://drive.google.com/file/d/1BBCi9e2i3xvUwnKIdLTxB-MJ6l6yIAZl/view?usp=share_link
If I build 3S4P battery, will it be ok? Or maybe I need to switch to 4S? Or Li-Ion is not suitable for such setup?
Those batteries can’t supply the current required. They are sagging to <9V and the Motor outputs are maxed out. 4S might work.
