Hello again,
I did a test flight today and when I activated RTL at the end of the flight then the helicopter went to home location, but started to very strangely act in roll and pitch axis. It was sort of like “lurking” around the home point.
I have also noticed that in loiter the aircraft seems to be moving around more than it should. Especially today as there wasn’t any wind. The poorer position holding was noticed after I changed the GPS setup to two Zubax GNSS 2 units. Previous version of the aircraft used one 3DR GPS and one Zubax GNSS 2 and I haven’t noticed such poor location holding on that one.
Maybe somebody has some ideas what might be the issue and how to solve it?
Also, it’s not evident from this log as this was only hover, but when I have done Auto flights then it tends to be a bit off-course and when it needs to do a loiter unlimited at the end of the mission, then the helicopter starts to again “lurk around” in the vicinity and it also yaws with respect to the location. It kinda looks like a fixed wing loitering around a point and that is strange.
Log file of the flight is here
