Hi, I’m planning to custom build V-Style 8motor(X8) multicopter.
In GUI V-style looks support only 4 motor.
Is it possible to use V-Style 8motor setup with Pixhawk?
Thank you for you advice.
Personally, I’m guessing you’d probably be happier with a flat X8. To answer your question, I don’t believe there’s support for that. If you must, I would ask in drones-discuss about the correct coefficients for a V-tail X8 frame type.
jschall Thank you very much for your replay.
Yes I’d like to make foldable X8 so good to use V-style.
Thank you for your help!
