Porting to a stm32f411ccu6 flight controller board
I have an icm-20948 sensor and a stm32f411ccu6 microcontroller
I know that the Ardupilot for the entire project requires more than 1 MB of flash, I need to collect some examples, which take 300-400 kB when compiled.
I want to compile a couple of simple examples.
./waf build --target examples/AHRS_Test -v
./waf build --target examples/INS_generic -v
What I did was study the documentation
Porting to a new flight controller board — Dev documentation
and
ardupilot/libraries/AP_HAL_ChibiOS/hwdef/fmuv3/hwdef.dat at master · ArduPilot/ardupilot · GitHub
Added the hwdef-bl.dat file to the folder
Arduino\libraries\ardupilot\libraries\AP_HAL_ChibiOS\hwdef\Stm32f411ccu6
The contents of the file hwdef-bl.dat are
# hw definition file for Stm32f411ccu6 hardware
# MCU class and specific type
# MCU STM32F4xx STM32F411xx
MCU STM32F4xx STM32F411xE
# board ID for firmware load
APJ_BOARD_ID 5502
# crystal frequency
OSCILLATOR_HZ 10000000
FLASH_SIZE_KB 512
# bootloader is installed at zero offset
FLASH_RESERVE_START_KB 64
# LEDs
PC13 LED_BOOTLOADER OUTPUT LOW
define HAL_LED_ON 2
# the location where the bootloader will put the firmware
FLASH_BOOTLOADER_LOAD_KB 64
# order of UARTs (and USB)
SERIAL_ORDER OTG1 USART1 USART2
# USART1
PA9 USART1_TX USART1
PA10 USART1_RX USART1
# alternative RC input using UART
PA2 USART2_TX USART2 NODMA
PA3 USART2_RX USART2 NODMA ALT(1)
PA11 OTG_FS_DM OTG1
PA12 OTG_FS_DP OTG1
# Add CS pins to ensure they are high in bootloader
PB10 FLASH_CS CS
I decided to start by compiling a bootloader.
./waf distclean
python3 ./Tools/scripts/build_bootloaders.py Stm32f411ccu6
Here I would like to immediately make a comment that when it was chosen like this:
Then the python script for creating a bootloader produced a lot of errors and for a long time I could not understand why, and then I found in this file
\ardupilot\modules\ChibiOS\os\common\ext\ST\STM32F4xx\stm32f4xx.h
this code
#elif defined(STM32F411xE)
 #include "stm32f411xe.h"
Then added it to the folder
\ardupilot\libraries\AP_HAL_ChibiOS\hwdef\scripts
file STM32F411xE.py
#!/usr/bin/env python
these tables are generated from the STM32 datasheets for the
STM32F41x
# additional build information for ChibiOS
build = {
    "CHIBIOS_STARTUP_MK"  : "os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f4xx.mk",
    "CHIBIOS_PLATFORM_MK" : "os/hal/ports/STM32/STM32F4xx/platform.mk"
# MCU parameters
mcu = {
    # ram map, as list of (address, size-kb, flags)
    # flags of 1 means DMA-capable
    # flags of 2 means faster memory for CPU intensive work
    'RAM_MAP' : [
        (0x20000000, 256, 1), # main memory, DMA safe
    'EXPECTED_CLOCK' : 100000000,
    'DEFINES' : {
        'STM32F4' : '1',
AltFunction_map = {
	# format is PIN:FUNCTION : AFNUM
	# extracted from tabula-AF-F405.csv
	"PA0:ETH_MII_CRS"   	:	11,
	"PA0:EVENTOUT"      	:	15,
	"PA0:TIM2_CH1"  	:	1,
	"PA0:TIM2_ETR"  	:	1,
	"PA0:TIM5_CH1"      	:	2,
	"PA0:TIM8_ETR"      	:	3,
	"PA0:UART4_TX"      	:	8,
	"PA0:USART2_CTS"    	:	7,
	"PA10:DCMI_D1"      	:	13,
	"PA10:EVENTOUT"     	:	15,
	"PA10:OTG_FS_ID"    	:	10,
	"PA10:TIM1_CH3"     	:	1,
	"PA10:USART1_RX"    	:	7,
	"PA11:CAN1_RX"      	:	9,
	"PA11:EVENTOUT"     	:	15,
	"PA11:OTG_FS_DM"    	:	10,
	"PA11:TIM1_CH4"     	:	1,
	"PA11:USART1_CTS"   	:	7,
	"PA12:CAN1_TX"      	:	9,
	"PA12:EVENTOUT"     	:	15,
	"PA12:OTG_FS_DP"    	:	10,
	"PA12:TIM1_ETR"     	:	1,
	"PA12:USART1_RTS"   	:	7,
	"PA13:EVENTOUT"     	:	15,
	"PA13:JTMS-SWDIO"   	:	0,
	"PA14:EVENTOUT"     	:	15,
	"PA14:JTCK-SWCLK"   	:	0,
	"PA15:EVENTOUT"     	:	15,
	"PA15:JTDI"         	:	0,
	"PA15:SPI1_NSS"     	:	5,
	"PA15:SPI3_NSS"     	:	6,
	"PA15:TIM2_CH1"     	:	1,
	"PA15:TIM2_ETR"     	:	1,
	"PA1:ETH_MII_RX_CLK"	:	11,
	"PA1:ETH_RMII__REF_CLK"	:	11,
	"PA1:EVENTOUT"      	:	15,
	"PA1:TIM2_CH2"      	:	1,
	"PA1:TIM5_CH2"      	:	2,
	"PA1:UART4_RX"      	:	8,
	"PA1:USART2_RTS"    	:	7,
	"PA2:ETH_MDIO"      	:	11,
	"PA2:EVENTOUT"      	:	15,
	"PA2:TIM2_CH3"      	:	1,
	"PA2:TIM5_CH3"      	:	2,
	"PA2:TIM9_CH1"      	:	3,
	"PA2:USART2_TX"     	:	7,
	"PA3:ETH_MII_COL"   	:	11,
	"PA3:EVENTOUT"      	:	15,
	"PA3:OTG_HS_ULPI_D0"	:	10,
	"PA3:TIM2_CH4"      	:	1,
	"PA3:TIM5_CH4"      	:	2,
	"PA3:TIM9_CH2"      	:	3,
	"PA3:USART2_RX"     	:	7,
	"PA4:DCMI_HSYNC"    	:	13,
	"PA4:EVENTOUT"      	:	15,
	"PA4:OTG_HS_SOF"    	:	12,
	"PA4:SPI1_NSS"      	:	5,
	"PA4:SPI3_NSS"		:	6,
	"PA4:I2S3_WS"		:	6,
	"PA4:USART2_CK"     	:	7,
	"PA5:EVENTOUT"      	:	15,
	"PA5:OTG_HS_ULPI_CK"	:	10,
	"PA5:SPI1_SCK"      	:	5,
	"PA5:TIM2_CH1"  	:	1,
	"PA5:TIM2_ETR"  	:	1,
	"PA5:TIM8_CH1N"     	:	3,
	"PA6:DCMI_PIXCK"    	:	13,
	"PA6:EVENTOUT"      	:	15,
	"PA6:SPI1_MISO"     	:	5,
	"PA6:TIM1_BKIN"     	:	1,
	"PA6:TIM3_CH1"      	:	2,
	"PA7:ETH_MII_RX_DV" 	:	11,
	"PA7:ETH_RMII_CRS_DV"	:	11,
	"PA7:EVENTOUT"      	:	15,
	"PA7:SPI1_MOSI"     	:	5,
	"PA7:TIM14_CH1"     	:	9,
	"PA7:TIM1_CH1N"     	:	1,
	"PA7:TIM3_CH2"      	:	2,
	"PA7:TIM8_CH1N"     	:	3,
	"PA8:EVENTOUT"      	:	15,
	"PA8:I2C3_SCL"      	:	4,
	"PA8:MCO1"          	:	0,
	"PA8:OTG_FS_SOF"    	:	10,
	"PA8:TIM1_CH1"      	:	1,
	"PA8:USART1_CK"     	:	7,
	"PA9:DCMI_D0"       	:	13,
	"PA9:EVENTOUT"      	:	15,
	"PA9:I2C3_SMBA"     	:	4,
	"PA9:TIM1_CH2"      	:	1,
	"PA9:USART1_TX"     	:	7,
	"PB0:ETH_MII_RXD2"  	:	11,
	"PB0:EVENTOUT"      	:	15,
	"PB0:OTG_HS_ULPI_D1"	:	10,
	"PB0:TIM1_CH2N"     	:	1,
	"PB0:TIM3_CH3"      	:	2,
	"PB10:ETH_MII_RX_ER"	:	11,
	"PB10:EVENTOUT"     	:	15,
	"PB10:I2C2_SCL"     	:	4,
	"PB10:OTG_HS_ULPI_D3"	:	10,
	"PB10:SPI2_SCK"		:	5,
	"PB10:I2S2_CK"		:	5,
	"PB10:TIM2_CH3"     	:	1,
	"PB12:CAN2_RX"      	:	9,
	"PB12:EVENTOUT"     	:	15,
	"PB12:I2C2_SMBA"    	:	4,
	"PB12:OTG_HS_ID"    	:	12,
	"PB12:OTG_HS_ULPI_D5"	:	10,
	"PB12:SPI2_NSS"		:	5,
	"PB12:I2S2_WS"		:	5,
	"PB12:TIM1_BKIN"    	:	1,
	"PB13:CAN2_TX"      	:	9,
	"PB13:ETH_MII_TXD1" 	:	11,
	"PB13:ETH_RMII_TXD1"	:	11,
	"PB13:EVENTOUT"     	:	15,
	"PB13:OTG_HS_ULPI_D6"	:	10,
	"PB13:SPI2_SCK"		:	5,
	"PB13:I2S2_CK"		:	5,
	"PB13:TIM1_CH1N"    	:	1,
	"PB14:EVENTOUT"     	:	15,
	"PB14:I2S2EXT_SD"   	:	6,
	"PB14:OTG_HS_DM"    	:	12,
	"PB14:SPI2_MISO"    	:	5,
	"PB14:TIM12_CH1"    	:	9,
	"PB14:TIM1_CH2N"    	:	1,
	"PB14:TIM8_CH2N"    	:	3,
	"PB15:RTC_REFIN"    	:	0,
	"PB15:TIM1_CH3N"    	:	1,
	"PB15:TIM8_CH3N"    	:	3,
	"PB15:SPI2_MOSI"    	:	5,
	"PB15:I2S2_SD"    	:	5,
	"PB15:TIM12_CH2"    	:	9,
	"PB15:OTG_HS_DP"    	:	12,
	"PB15:EVENTOUT"    	:	15,
	"PB1:ETH_MII_RXD3"  	:	11,
	"PB1:EVENTOUT"      	:	15,
	"PB1:OTG_HS_ULPI_D2"	:	10,
	"PB1:TIM1_CH3N"     	:	1,
	"PB1:TIM3_CH4"      	:	2,
	"PB2:EVENTOUT"      	:	15,
	"PB3:EVENTOUT"      	:	15,
	"PB3:JTDO"          	:	0,
	"PB3:SPI1_SCK"      	:	5,
	"PB3:I2S3_CK"		:	6,
	"PB3:SPI3_SCK"		:	6,
	"PB3:TIM2_CH2"      	:	1,
	"PB3:TRACESWO"      	:	0,
	"PB4:EVENTOUT"      	:	15,
	"PB4:I2S3EXT_SD"    	:	7,
	"PB4:NJTRST"        	:	0,
	"PB4:SPI1_MISO"     	:	5,
	"PB4:SPI3_MISO"     	:	6,
	"PB4:TIM3_CH1"      	:	2,
	"PB5:CAN2_RX"       	:	9,
	"PB5:DCMI_D10"      	:	13,
	"PB5:ETH_PPS_OUT"   	:	11,
	"PB5:EVENTOUT"      	:	15,
	"PB5:I2C1_SMBA"     	:	4,
	"PB5:OTG_HS_ULPI_D7"	:	10,
	"PB5:SPI1_MOSI"     	:	5,
	"PB5:SPI3_MOSI"     	:	6,
	"PB5:I2S3_SD"       	:	6,
	"PB5:TIM3_CH2"      	:	2,
	"PB6:CAN2_TX"       	:	9,
	"PB6:DCMI_D5"       	:	13,
	"PB6:EVENTOUT"      	:	15,
	"PB6:I2C1_SCL"      	:	4,
	"PB6:TIM4_CH1"      	:	2,
	"PB6:USART1_TX"     	:	7,
	"PB7:DCMI_VSYNC"    	:	13,
	"PB7:EVENTOUT"      	:	15,
	"PB7:FSMC_NL"       	:	12,
	"PB7:I2C1_SDA"      	:	4,
	"PB7:TIM4_CH2"      	:	2,
	"PB7:USART1_RX"     	:	7,
	"PB8:CAN1_RX"       	:	9,
	"PB8:DCMI_D6"       	:	13,
	"PB8:ETH_MII_TXD3"  	:	11,
	"PB8:EVENTOUT"      	:	15,
	"PB8:I2C1_SCL"      	:	4,
	"PB8:SDIO_D4"       	:	12,
	"PB8:TIM10_CH1"     	:	3,
	"PB8:TIM4_CH3"      	:	2,
	"PB9:CAN1_TX"       	:	9,
	"PB9:DCMI_D7"       	:	13,
	"PB9:EVENTOUT"      	:	15,
	"PB9:I2C1_SDA"      	:	4,
	"PB9:SDIO_D5"       	:	12,
	"PB9:SPI2_NSS"		:	5,
	"PB9:I2S2_WS"		:	5,
	"PB9:TIM11_CH1"     	:	3,
	"PB9:TIM4_CH4"      	:	2,
	"PC13:EVENTOUT"     	:	15,
	"PC14:EVENTOUT"     	:	15,
	"PC15:EVENTOUT"     	:	15,
ADC1_map = {
	# format is PIN : ADC1_CHAN
	# extracted from tabula-addfunc-F405.csv
	"PA0"	:	0,
	"PA1"	:	1,
	"PA2"	:	2,
	"PA3"	:	3,
	"PA4"	:	4,
	"PA5"	:	5,
	"PA6"	:	6,
	"PA7"	:	7,
	"PB0"	:	8,
	"PB1"	:	9,
DMA_Map = {
	# format is (DMA_TABLE, StreamNum, Channel)
	# extracted from tabula-STM32F405-DMA.csv
	"ADC1"    	:	[(2,0,0),(2,4,0)],
	"I2C1_RX" 	:	[(1,0,1),(1,5,1)],
	"I2C1_TX" 	:	[(1,6,1),(1,7,1)],
	"I2C2_RX" 	:	[(1,2,7),(1,3,7)],
	"I2C2_TX" 	:	[(1,7,7)],
	"I2C3_RX" 	:	[(1,2,3)],
	"I2C3_TX" 	:	[(1,4,3)],
	"I2S2_EXT_RX"	:	[(1,3,3)],
	"I2S2_EXT_TX"	:	[(1,4,2)],
	"I2S3_EXT_RX"	:	[(1,2,2),(1,0,3)],
	"I2S3_EXT_TX"	:	[(1,5,2)],
	"SDIO"    	:	[(2,3,4),(2,6,4)],
	"SPI1_RX" 	:	[(2,0,3),(2,2,3)],
	"SPI1_TX" 	:	[(2,3,3),(2,5,3)],
	"SPI2_RX" 	:	[(1,3,0)],
	"SPI2_TX" 	:	[(1,4,0)],
	"SPI3_RX" 	:	[(1,0,0),(1,2,0)],
	"SPI3_TX" 	:	[(1,5,0),(1,7,0)],
	"SPI4_RX" 	:	[(2,0,4),(2,3,5)],
	"SPI4_TX" 	:	[(2,1,4),(2,4,5)],
	"SPI5_RX" 	:	[(2,3,2),(2,5,7)],
	"SPI5_TX" 	:	[(2,4,2),(2,6,7)],
	"TIM1_CH1"	:	[(2,6,0),(2,1,6),(2,3,6)],
	"TIM1_CH2"	:	[(2,6,0),(2,2,6)],
	"TIM1_CH3"	:	[(2,6,0),(2,6,6)],
	"TIM1_CH4"	:	[(2,4,6)],
	"TIM1_COM"	:	[(2,4,6)],
	"TIM1_TRIG"	:	[(2,0,6),(2,4,6)],
	"TIM1_UP" 	:	[(2,5,6)],
	"TIM2_CH1"	:	[(1,5,3)],
	"TIM2_CH2"	:	[(1,6,3)],
	"TIM2_CH3"	:	[(1,1,3)],
	"TIM2_CH4"	:	[(1,6,3),(1,7,3)],
	"TIM2_UP" 	:	[(1,1,3),(1,7,3)],
	"TIM3_CH1"	:	[(1,4,5)],
	"TIM3_CH2"	:	[(1,5,5)],
	"TIM3_CH3"	:	[(1,7,5)],
	"TIM3_CH4"	:	[(1,2,5)],
	"TIM3_TRIG"	:	[(1,4,5)],
	"TIM3_UP" 	:	[(1,2,5)],
	"TIM4_CH1"	:	[(1,0,2)],
	"TIM4_CH2"	:	[(1,3,2)],
	"TIM4_CH3"	:	[(1,7,2)],
	"TIM4_UP" 	:	[(1,6,2)],
	"TIM5_CH1"	:	[(1,2,6)],
	"TIM5_CH2"	:	[(1,4,6)],
	"TIM5_CH3"	:	[(1,0,6)],
	"TIM5_CH4"	:	[(1,1,6),(1,3,6)],
	"TIM5_TRIG"	:	[(1,1,6),(1,3,6)],
	"TIM5_UP" 	:	[(1,0,6),(1,6,6)],
	"USART1_RX"	:	[(2,2,4),(2,5,4)],
	"USART1_TX"	:	[(2,7,4)],
	"USART2_RX"	:	[(1,5,4)],
	"USART2_TX"	:	[(1,6,4)],
I registered DMA, ADC and PINs in it… well, I wrote as much as I could, at least the command
./waf configure --board Stm32f411ccu6 -v
It didn’t show any errors.
My problem remains the incomprehensible situation with the processor frequency, clocks and voltage.
I can’t edit the file correctly
stm32f47_mcuconf.h
And the meaning
Which the file needs
hal_lld_type1.h
Console command
It produces errors like this
Building for Stm32f411ccu6
Running (./waf configure --board Stm32f411ccu6 --bootloader --no-submodule-update --Werror)
Setting top to                           : /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot
Setting out to                           : /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build
Autoconfiguration                        : enabled
Checking for program 'python'            : /usr/bin/python3
Checking for python version >= 3.6.9     : 3.10.12
Setting board to                         : Stm32f411ccu6
Using toolchain                          : arm-none-eabi
Checking for 'g++' (C++ compiler)        : /usr/bin/arm-none-eabi-g++
Checking for 'gcc' (C compiler)          : /usr/bin/arm-none-eabi-gcc
Checking for program 'arm-none-eabi-nm'  : /usr/bin/arm-none-eabi-nm
Checking for c flags '-MMD'              : yes
Checking for cxx flags '-MMD'            : yes
CXX Compiler                             : g++ 10.3.1
Checking for program 'make'              : /usr/bin/make
Checking for program 'arm-none-eabi-objcopy' : /usr/bin/arm-none-eabi-objcopy
Setup for MCU STM32F411xE
Writing hwdef setup in /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6/hwdef.h
Writing DMA map
Setting up as bootloader
Generating ldscript.ld
Checking for env.py
env set ENABLE_DFU_BOOT=0
env set PROCESS_STACK=0x1C00
env set MAIN_STACK=0x600
env set IOMCU_FW=0
env set PERIPH_FW=0
env set BOARD_FLASH_SIZE=512
env set EXT_FLASH_SIZE_MB=0
env set INT_FLASH_PRIMARY=False
env set ENABLE_CRASHDUMP=False
env set CPU_FLAGS=['-mcpu=cortex-m4', '-mfpu=fpv4-sp-d16', '-mfloat-abi=hard']
env set CORTEX=cortex-m4
env set APJ_BOARD_ID=5502
env set APJ_BOARD_TYPE=STM32F411xE
env set USBID=0x1209/0x5741
env set FLASH_RESERVE_START_KB=64
env set EXT_FLASH_RESERVE_START_KB=0
env set FLASH_TOTAL=65536
env set HAS_EXTERNAL_FLASH_SECTIONS=0
env set CHIBIOS_BUILD_FLAGS=USE_FATFS=no CHIBIOS_STARTUP_MK=os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f4xx.mk CHIBIOS_PLATFORM_MK=os/hal/ports/STM32/STM32F4xx/platform.mk MCU=cortex-m4
Enabling ChibiOS asserts                     : no
Disabling Watchdog                           : no
Enabling malloc guard                        : no
Enabling ChibiOS thread statistics           : no
Enabling -Werror                             : yes
Checking for intelhex module:                : OK
Enabled OpenDroneID                          : no
Enabled firmware ID checking                 : no
GPS Debug Logging                            : no
Enabled custom controller                    : no
Checking for HAVE_CMATH_ISFINITE             : yes
Checking for HAVE_CMATH_ISINF                : yes
Checking for HAVE_CMATH_ISNAN                : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE    : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE    : yes
Checking for header endian.h                   : not found
Checking for header byteswap.h                 : not found
Checking for HAVE_MEMRCHR                      : no
Configured VSCode Intellisense:                : no
DC_DSDL compiler                               : /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/modules/DroneCAN/dronecan_dsdlc/dronecan_dsdlc.py
Source is git repository                       : yes
Update submodules                              : no
Checking for program 'git'                     : /usr/bin/git
Gtest                                          : STM32 boards currently don't support compiling gtest
Checking for program 'arm-none-eabi-size'      : /usr/bin/arm-none-eabi-size
Benchmarks                                     : disabled
Unit tests                                     : disabled
Scripting                                      : disabled
Scripting runtime checks                       : enabled
Debug build                                    : disabled
Coverage build                                 : disabled
Force 32-bit build                             : disabled
Checking for program 'rsync'                   : /usr/bin/rsync
Removing target_list file /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6/target_list
'configure' finished successfully (2.090s)
Running (./waf clean)
'clean' finished successfully (5.721s)
Running (./waf bootloader)
Waf: Entering directory `/mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6'
Checking for env.py
No env.py found
Generating hwdef.h
Writing DMA map
Embedding file hwdef.dat:/mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6/hw.dat
[1/7] Creating build/Stm32f411ccu6/hwdef.h
[2/7] Creating build/Stm32f411ccu6/modules/ChibiOS/include_dirs
[3/7] Compiling libraries/AP_Scripting/generator/src/main.c
[4/7] Creating build/Stm32f411ccu6/ap_version.h
[5/7] Creating build/Stm32f411ccu6/chibios_flags.h
Writing DMA map
No change in hwdef.h
[6/7] Processing /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6/libraries/AP_Scripting/lua_generated_bindings.cpp,/mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6/libraries/AP_Scripting/lua_generated_bindings.h: libraries/AP_Scripting/generator/description/bindings.desc build/Stm32f411ccu6/gen-bindings -> build/Stm32f411ccu6/libraries/AP_Scripting/lua_generated_bindings.cpp build/Stm32f411ccu6/libraries/AP_Scripting/lua_generated_bindings.h
[7/7] Linking build/Stm32f411ccu6/modules/ChibiOS/libch.a
[1/107] ChibiOS: Compiling crt0_v7m.S
[2/107] ChibiOS: Compiling vectors.S
[3/107] ChibiOS: Compiling chcoreasm.S
[4/107] ChibiOS: Compiling chcore.c
[5/107] ChibiOS: Compiling crt1.c
[6/107] ChibiOS: Compiling bufstreams.c
[7/107] ChibiOS: Compiling chprintf.c
[8/107] ChibiOS: Compiling chscanf.c
[9/107] ChibiOS: Compiling memstreams.c
[10/107] ChibiOS: Compiling nullstreams.c
In file included from ../../libraries/AP_HAL_ChibiOS/hwdef/common/mcuconf.h:55,
                 from ../../libraries/AP_HAL_ChibiOS/hwdef/common/halconf.h:48,
                 from ../../modules/ChibiOS/os/hal/include/hal.h:32,
                 from ../../modules/ChibiOS/os/hal/lib/streams/chprintf.c:31:
../../libraries/AP_HAL_ChibiOS/hwdef/common/stm32f47_mcuconf.h:197:2: error: #error "Unsupported F4 HSE clock"
  197 | #error "Unsupported F4 HSE clock"
In file included from ../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld.h:33,
                 from ../../modules/ChibiOS/os/hal/include/hal.h:257,
../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h:1595:2: error: #error "STM32_PLLCLKOUT outside acceptable range (STM32_PLLOUT_MIN...STM32_PLLOUT_MAX)"
 1595 | #error "STM32_PLLCLKOUT outside acceptable range (STM32_PLLOUT_MIN...STM32_PLLOUT_MAX)"
../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h:1615:2: error: #error "STM32_SYSCLK above maximum rated frequency (STM32_SYSCLK_MAX)"
 1615 | #error "STM32_SYSCLK above maximum rated frequency (STM32_SYSCLK_MAX)"
../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h:1696:2: error: #error "STM32_HCLK exceeding maximum frequency (STM32_SYSCLK_MAX)"
 1696 | #error "STM32_HCLK exceeding maximum frequency (STM32_SYSCLK_MAX)"
../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h:1720:2: error: #error "STM32_PCLK1 exceeding maximum frequency (STM32_PCLK1_MAX)"
 1720 | #error "STM32_PCLK1 exceeding maximum frequency (STM32_PCLK1_MAX)"
../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld_type1.h:1744:2: error: #error "STM32_PCLK2 exceeding maximum frequency (STM32_PCLK2_MAX)"
 1744 | #error "STM32_PCLK2 exceeding maximum frequency (STM32_PCLK2_MAX)"
In file included from ../../modules/ChibiOS/os/hal/include/hal.h:257,
../../modules/ChibiOS/os/hal/ports/STM32/STM32F4xx/hal_lld.h:261:2: error: #error "invalid frequency at specified VDD level"
  261 | #error "invalid frequency at specified VDD level"
In file included from ../../modules/ChibiOS/os/hal/include/hal_usb.h:373,
                 from ../../modules/ChibiOS/os/hal/include/hal.h:334,
../../modules/ChibiOS/os/hal/ports/STM32/LLD/OTGv1/hal_usb_lld.h:246:2: error: #error "the USB OTG driver requires a 48MHz clock"
  246 | #error "the USB OTG driver requires a 48MHz clock"
                 from ../../modules/ChibiOS/os/hal/lib/streams/chscanf.c:32:
make: *** [../../libraries/AP_HAL_ChibiOS/hwdef/common/chibios_common.mk:243: modules/ChibiOS/obj/chprintf.o] Error 1
make: *** Waiting for unfinished jobs....
                 from ../../modules/ChibiOS/os/hal/lib/streams/bufstreams.c:32:
                 from ../../modules/ChibiOS/os/hal/lib/streams/nullstreams.c:26:
make: *** [../../libraries/AP_HAL_ChibiOS/hwdef/common/chibios_common.mk:243: modules/ChibiOS/obj/chscanf.o] Error 1
                 from ../../modules/ChibiOS/os/hal/lib/streams/memstreams.c:28:
make: *** [../../libraries/AP_HAL_ChibiOS/hwdef/common/chibios_common.mk:243: modules/ChibiOS/obj/bufstreams.o] Error 1
make: *** [../../libraries/AP_HAL_ChibiOS/hwdef/common/chibios_common.mk:243: modules/ChibiOS/obj/nullstreams.o] Error 1
make: *** [../../libraries/AP_HAL_ChibiOS/hwdef/common/chibios_common.mk:243: modules/ChibiOS/obj/memstreams.o] Error 1
No target_list file found, creating
Generating compile_commands.json
Build commands will be stored in build/Stm32f411ccu6/compile_commands.json
Waf: Leaving directory `/mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6'
Build failed
 -> task in 'ChibiOS_lib' failed (exit status 2):
        {task 139798791369808: ChibiOS_lib hwdef.h,hw.dat,ldscript.ld,common.ld,include_dirs,board.c,board.h,bouncebuffer.c,bouncebuffer.h,chconf.h,crashdump.c,ffconf.h,flash.c,flash.h,halconf.h,hrt.c,hrt.h,malloc.c,mcuconf.h,poll.h,ppm.h,spi_hook.h,stdio.h,stm32_util.c,stm32_util.h,stm32f1_mcuconf.h,stm32f3_mcuconf.h,stm32f47_mcuconf.h,stm32g4_mcuconf.h,stm32h7_A3_mcuconf.h,stm32h7_mcuconf.h,stm32h7_type2_mcuconf.h,stm32l4+_mcuconf.h,stm32l4_mcuconf.h,stubs.c,usbcfg.c,usbcfg.h,usbcfg_common.c,usbcfg_dualcdc.c,watchdog.c,watchdog.h,chibios_board.mk,chibios_common.mk,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,buzzer.c,buzzer.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,board.c,board.h,hal.h,hal_adc.h,hal_buffered_serial.h,hal_buffers.h,hal_can.h,hal_channels.h,hal_crypto.h,hal_dac.h,hal_efl.h,hal_eicu.h,hal_files.h,hal_flash.h,hal_gpt.h,hal_i2c.h,hal_i2s.h,hal_icu.h,hal_ioblock.h,hal_mac.h,hal_mii.h,hal_mmc_spi.h,hal_mmcsd.h,hal_objects.h,hal_pal.h,hal_persistent.h,hal_pwm.h,hal_queues.h,hal_rtc.h,hal_sdc.h,hal_serial.h,hal_serial_usb.h,hal_sio.h,hal_spi.h,hal_spi_v1.h,hal_spi_v2.h,hal_st.h,hal_streams.h,hal_trng.h,hal_uart.h,hal_usb.h,hal_usb_cdc.h,hal_usb_msd.h,hal_wdg.h,hal_wspi.h,hal_buffered_sio.c,hal_buffered_sio.h,hal_mfs.c,hal_mfs.h,hal_flash_device.c,hal_flash_device.h,hal_flash_device.c,hal_flash_device.h,hal_serial_nor.c,hal_serial_nor.h,hal_i2c_lld.c,hal_i2c_lld.h,bufstreams.c,bufstreams.h,chprintf.c,chprintf.h,chscanf.c,chscanf.h,memstreams.c,memstreams.h,nullstreams.c,nullstreams.h,osal_vt.c,osal_vt.h,osal.c,osal.h,osal.c,osal.h,chcore_timer.h,osal.c,osal.h,osal.c,osal.h,aducm_cc.h,aducm_gp.h,aducm_isr.c,aducm_isr.h,aducm_registry.h,hal_lld.c,hal_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_st_lld.c,hal_st_lld.h,aducm_uart.h,hal_serial_lld.c,hal_serial_lld.h,aducm_wut.h,hal_st_lld.c,hal_st_lld.h,avr_pins.h,avr_timers.h,hal_lld.c,hal_lld.h,hal_adc_lld.c,hal_adc_lld.h,hal_ext_lld.c,hal_ext_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_i2c_lld.c,hal_i2c_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_st_lld.c,hal_st_lld.h,hal_gpt_lld.c,hal_gpt_lld.h,hal_icu_lld.c,hal_icu_lld.h,hal_pwm_lld.c,hal_pwm_lld.h,hal_st_lld.c,hal_st_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal_usb_lld.c,hal_usb_lld.h,hal_lld.c,hal_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_st_lld.c,hal_st_lld.h,hal_st_lld.c,hal_st_lld.h,hal_uart_lld.c,hal_uart_lld.h,avr_pins.h,avr_timers.h,hal_lld.c,hal_lld.h,hal_crc.c,hal_crc.h,hal_crc_lld.c,hal_crc_lld.h,xmega_crc.h,hal_crypto_lld.c,hal_crypto_lld.h,hal_dac_lld.c,hal_dac_lld.h,xmega_dma_lld.c,xmega_dma_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_st_lld.c,hal_st_lld.h,hal_st_lld.c,hal_st_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal_uart_lld.c,hal_uart_lld.h,hal_wdg_lld.c,hal_wdg_lld.h,hal_lld.c,hal_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_st_lld.c,hal_st_lld.h,vic.c,vic.h,rp_dma.c,rp_dma.h,hal_pal_lld.c,hal_pal_lld.h,hal_i2c_lld.c,hal_i2c_lld.h,hal_rtc_lld.c,hal_rtc_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_st_lld.c,hal_st_lld.h,hal_sio_lld.c,hal_sio_lld.h,hal_wdg_lld.c,hal_wdg_lld.h,hal_lld.c,hal_lld.h,rp_fifo.h,rp_isr.c,rp_isr.h,rp_registry.h,hal_spi_lld.c,hal_spi_lld.h,spc5_dspi.h,spc5_edma.c,spc5_edma.h,hal_serial_lld.c,hal_serial_lld.h,hal_serial_lld.c,hal_serial_lld.h,spc5_linflex.h,hal_pal_lld.c,hal_pal_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_st_lld.c,hal_st_lld.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc560bc.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc560b.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc560d.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc560p.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc563m.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc564a.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc56ec.h,hal_lld.c,hal_lld.h,registers.h,spc5_registry.h,typedefs.h,xpc56el.h,hal_adc_lld.c,hal_adc_lld.h,hal_adc_lld.c,hal_adc_lld.h,hal_adc_lld.c,hal_adc_lld.h,hal_adc_lld.c,hal_adc_lld.h,hal_adc_lld.c,hal_adc_lld.h,stm32_bdma.c,stm32_bdma.h,hal_can_lld.c,hal_can_lld.h,hal_crypto_lld.c,hal_crypto_lld.h,hal_dac_lld.c,hal_dac_lld.h,stm32_dma.c,stm32_dma.h,stm32_dma.c,stm32_dma.h,stm32_exti.c,stm32_exti.h,hal_can_lld.c,hal_can_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_pal_lld.c,hal_pal_lld.h,stm32_gpio.h,hal_pal_lld.c,hal_pal_lld.h,stm32_gpio.h,hal_i2c_lld.c,hal_i2c_lld.h,hal_i2c_lld.c,hal_i2c_lld.h,hal_i2c_lld.c,hal_i2c_lld.h,hal_mac_lld.c,hal_mac_lld.h,hal_mac_lld.c,hal_mac_lld.h,stm32_mdma.c,stm32_mdma.h,hal_wspi_lld.c,hal_wspi_lld.h,hal_wspi_lld.c,hal_wspi_lld.h,hal_usb_lld.c,hal_usb_lld.h,stm32_otg.h,hal_wspi_lld.c,hal_wspi_lld.h,hal_wspi_lld.c,hal_wspi_lld.h,hal_trng_lld.c,hal_trng_lld.h,hal_rtc_lld.c,hal_rtc_lld.h,hal_rtc_lld.c,hal_rtc_lld.h,hal_rtc_lld.c,hal_rtc_lld.h,hal_sdc_lld.c,hal_sdc_lld.h,hal_sdc_lld.c,hal_sdc_lld.h,hal_sdc_lld.c,hal_sdc_lld.h,hal_i2s_lld.c,hal_i2s_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_spi_v2_lld.c,hal_spi_v2_lld.h,hal_i2s_lld.c,hal_i2s_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_spi_v2_lld.c,hal_spi_v2_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_spi_v2_lld.c,hal_spi_v2_lld.h,hal_st_lld.c,hal_st_lld.h,hal_st_lld.c,hal_st_lld.h,hal_eicu_lld.c,hal_eicu_lld.h,hal_gpt_lld.c,hal_gpt_lld.h,hal_icu_lld.c,hal_icu_lld.h,hal_pwm_lld.c,hal_pwm_lld.h,stm32_tim.h,hal_serial_lld.c,hal_serial_lld.h,hal_uart_lld.c,hal_uart_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal_sio_lld.c,hal_sio_lld.h,hal_uart_lld.c,hal_uart_lld.h,stm32_usart.h,hal_serial_lld.c,hal_serial_lld.h,hal_sio_lld.c,hal_sio_lld.h,hal_uart_lld.c,hal_uart_lld.h,stm32_usart.h,hal_usb_lld.c,hal_usb_lld.h,stm32_usb.h,hal_usb_lld.c,hal_usb_lld.h,hal_wdg_lld.c,hal_wdg_lld.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_adc_lld.c,hal_adc_lld.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,hal_lld_f100.h,hal_lld_f103.h,hal_lld_f105_f107.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_adc_lld.c,hal_adc_lld.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,hal_lld_type1.h,hal_lld_type2.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_lld.c,hal_lld.h,hal_lld_type1.h,hal_lld_type2.h,hal_lld_type3.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_adc_lld.c,hal_adc_lld.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,hal_efl_lld.c,hal_efl_lld.h,hal_lld.c,hal_lld.h,stm32_dmamux.h,stm32_isr.c,stm32_isr.h,stm32_rcc.h,stm32_registry.h,cache.h,mpu_v7m.h,nvic.c,nvic.h,sau.c,sau.h,hal_lld.c,hal_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_sio_lld.c,hal_sio_lld.h,hal_st_lld.c,hal_st_lld.h,console.c,console.h,hal_pal_lld.c,hal_pal_lld.h,hal_st_lld.c,hal_st_lld.h,hal_lld.c,hal_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal_lld.c,hal_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal.c,hal_adc.c,hal_buffered_serial.c,hal_buffers.c,hal_can.c,hal_crypto.c,hal_dac.c,hal_efl.c,hal_eicu.c,hal_flash.c,hal_gpt.c,hal_i2c.c,hal_i2s.c,hal_icu.c,hal_mac.c,hal_mmc_spi.c,hal_mmcsd.c,hal_pal.c,hal_pwm.c,hal_queues.c,hal_rtc.c,hal_sdc.c,hal_serial.c,hal_serial_usb.c,hal_sio.c,hal_spi.c,hal_st.c,hal_trng.c,hal_uart.c,hal_usb.c,hal_usb_msd.c,hal_wdg.c,hal_wspi.c,board.c,board.h,hal_adc_lld.c,hal_adc_lld.h,hal_can_lld.c,hal_can_lld.h,hal_crypto_lld.c,hal_crypto_lld.h,hal_dac_lld.c,hal_dac_lld.h,hal_efl_lld.c,hal_efl_lld.h,hal_gpt_lld.c,hal_gpt_lld.h,hal_i2c_lld.c,hal_i2c_lld.h,hal_i2s_lld.c,hal_i2s_lld.h,hal_icu_lld.c,hal_icu_lld.h,hal_lld.c,hal_lld.h,hal_mac_lld.c,hal_mac_lld.h,hal_pal_lld.c,hal_pal_lld.h,hal_pwm_lld.c,hal_pwm_lld.h,hal_rtc_lld.c,hal_rtc_lld.h,hal_sdc_lld.c,hal_sdc_lld.h,hal_serial_lld.c,hal_serial_lld.h,hal_sio_lld.c,hal_sio_lld.h,hal_spi_lld.c,hal_spi_lld.h,hal_spi_v2_lld.c,hal_spi_v2_lld.h,hal_st_lld.c,hal_st_lld.h,hal_trng_lld.c,hal_trng_lld.h,hal_uart_lld.c,hal_uart_lld.h,hal_usb_lld.c,hal_usb_lld.h,hal_wdg_lld.c,hal_wdg_lld.h,hal_wspi_lld.c,hal_wspi_lld.h,halconf.h,mcuconf.h,osal.c,osal.h,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,board.mk,hal.mk,hal_buffered_sio.mk,hal_mfs.mk,hal_flash_device.mk,hal_flash_device.mk,streams.mk,osal.mk,osal.mk,osal.mk,osal.mk,platform.mk,driver.mk,driver.mk,platform.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,platform.mk,driver.mk,driver.mk,driver.mk,driver.mk,platform.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,platform.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver_v2.mk,driver.mk,driver_v2.mk,driver.mk,driver_v2.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,driver.mk,platform.mk,platform.mk,platform_f105_f107.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform_type2.mk,platform.mk,platform.mk,platform.mk,platform_l412_l422.mk,platform_l432.mk,platform.mk,platform_l4p5_l4q5.mk,platform.mk,platform.mk,platform.mk,platform.mk,platform_v2.mk,platform.mk,platform.mk,platform.mk,board.mk,osal.mk,platform.mk,ap_romfs_embedded.h -> libch.a}
 (run with -v to display more information)
Build failed: ./waf bootloader
Failed boards: ['Stm32f411ccu6']
I hope that there will be someone who can help me.
Why? You could have just posted that and saved the lengthy post. Looks like a good one for the Discord channel.
Thank you.
They sent it from Github to the forum, wrote on discord - no one responded there at al :joy:l
Yea, use a supported microcontroller.
While I understand the motivation to expand the hardware on which ArduPilot runs, I can’t quite get the point of trying to cram it onto this one…
Yea, “f411” is an oldie but a goodie using search on the forum here…
I see that this is NOT impossible to do, you just don’t want to help…
If you get no action on the Discord channel for a use case like this you are shit out of luck.
Nobody knows what board you’re using. Does it have an external oscillator? You can set OSCILLATOR_HZ to 0 to use the RC oscillator. Won’t be very precise, but given you’re going ultra-low spec I doubt that it matters…
If there is a lot of a boards with STM32F411 family available, why buy another one?
I don’t want to support marketing games, more or less old hardware is enough for me.
And in general, why not learn and gain experience on younger microcontrollers in order to understand the operation of the same OS Chibi.
I succeeded to collect examples, as well as the actual firmware for the blackpill board with STM32F411CCU6 on board.
During launching OTG gives an error, complains about the lack of 48 MHz for USB, and as I understand it, this is an ChibiOS problem.
BUILD SUMMARY
Build directory: /mnt/c/Users/name/Documents/Arduino/libraries/ardupilot/build/Stm32f411ccu6
13:28:31 runner ['/usr/bin/arm-none-eabi-size', '-A', 'examples/AHRS_Test']
13:28:31 runner ['/usr/bin/arm-none-eabi-size', 'examples/AHRS_Test']
Target              Text (B)  Data (B)  BSS (B)  Total Flash Used (B)  Free Flash (B)  External Flash Used (B)
examples/AHRS_Test    524891      1012   261212                525903          457116  Not Applicable
'build' finished successfully (12m22.266s)
Why do you need to get a bootloader *hex file?
BUILD SUMMARY
bootloader/AP_Bootloader      9092        24   262124                  9116           56416  Not Applicable
'bootloader' finished successfully (49.043s)
Created Tools/bootloaders/Stm32f411ccu6_bl.bin
Created Tools/bootloaders/Stm32f411ccu6_bl.elf
Running (/usr/bin/python3 Tools/scripts/bin2hex.py --offset 0x08000000 Tools/bootloaders/Stm32f411ccu6_bl.bin Tools/bootloaders/Stm32f411ccu6_bl.hex)
Created Tools/bootloaders/Stm32f411ccu6_bl.hex
After all, I can just build the firmware without a bootloader.
I always flash stm32f411ccu6 via STlink v.2_1
Is a bootloader needed to interact with the MCU via USB?
Is there any way to disable unnecessary modules during compilation?
For example, I wanted to use an arduipilot without the DroneCAN and Mavlink module.
And many other libraries that, for example, you are not using at the moment - how to disable them during compilation?
Compiling for Windows via WSL is a separate form of art.
[ 68/969] Compiling libraries/APM_Control/AP_AutoTune.cpp
There are a lot of such lines.
If you could control the compilation of the necessary modules, you could increase the compilation speed.
For example
compilation INS_generic without BL takes 361 Kbytes, and with BL it takes 3.2 times more
369116 INS_generic.bin
1195420 INS_generic_with_bl.hex
Doesn’t have to do with marketing games at all. Ardupilot is very much oriented towards practical use. New hardware means new capabilities, and while older hardware is supported to a point, nobody is interested in proof-of-concept implementations that don’t have a use case. That’s not to say it isn’t possible, but you’ll be pretty much on your own.
I’m by no means an expert, but using the RP oscillator should allow USB to work, since it’s running at 16MHz, which can be scaled to 48MHz.
When I set these parameters in the hwdef.dat file
PA11 OTG_FS_DM OTG1
PA12 OTG_FS_DP OTG1
Then when assembling the firmware I get an error.
That’s why I don’t specify these parameters.|
upd.:
@MasterIphone . Hi. Do you have solved ? Do you know if work STM32F411CCU6 board with Ardupilot ?
