Point gimbal to height
Hi Guys,
I need to point my gimbal towards a fixed height point while the copter performs a vertical flight.
The gimbal is just a servo mounted on it’s side with a tube attached to the servo wheel. I then configured the servo on channel 12 as “Mount1Pitch”. This has the effect that if I pitch the drone the servo respond, which makes sense as it is in “RC Targeting” mode and is stabilized by the FC.
But what I want is for it not to respond to drone pitch but rather point to a given height. Using MP I switched to “GPS Point” mode and then on the map clicked and selected “Point Camera Here”. When prompted for a height, I picked some large height value much higher than the drone. I expected the servo to move but nothing happens.
Most likely I am completely misunderstanding how this should work, has anybody done something like this before and have some advice for me?
