Hello,I am trying to use the PM08-CAN to display the battery level of my drone. After going through all the settings on the official page, I have been able to test the motor and test fly successfully, and I can confirm that the voltage is displayed correctly, but I am not getting the current. Is there something wrong with the settings?
I had a look at the AP logs and I don’t see any issue so I think the issue must be with the voltage sensor itself.
Could you check the DroneCAN parameters for the device as shown here on the holybro website? In particular the BAT_AMP_PERVLT and BAT_VOLT_MULT parameters. Please note these are the device’s parameters exposed via DroneCAN. These are not the AP parameters.
Those two parameters are not currently changed because, as per Ampere per Volt, they should not be able to be set unless the current is displayed to some extent.
(If I have to set it all up myself, then I’m not doing my job as an “ammeter” particularly well…)
Since then, I have created another drone with the exact same configuration. I used the same parts and set it up the same way, and this time it worked properly. I was also able to obtain the current. It seems that the hardware that measured the current was broken. The settings were not wrong after all.
