Hello.
I’m building a quadcopter, wanted to use the Pixhawk 4’s power module, but I saw text saying the maximum current is 120 A.
Each motor draws a maximum of 48 A, that is 192 A current.
What should I do in this case, should I replace the power module?
I hope I wrote it understandable, thank you.
It’s unlikely you’ll hit your motors max current draw all at once. You can set MOT_BAT_CURR_MAX,80 and arducopter will limit PWM output to motors during testing, then decide if you need a different power distribution system
