hi ,
I am using apm 2.6 plane ardupilot
and I test it with manual mode many times it works good ,
but when i set the mode to auto I faced many problems such as :
when I change the mode ti Auto the throttle reduced and not response to the waypoints !
And I can’t test auto mode in the ground .
I need good information in mode setting and related setting .
dose there any way to test auto mode in ground ?
In what situation auto mode causes throttle low or fail?
Dose it important to use Airspeed for auto mode ?
what I need to do to verify my parameter list works success ?
A maybe helpful information about Auto parameter list
going to be crazy … plz don’t left without comment .
@ahmed,
Where did you get ArduPlane firmware version 2.6 from?
Why are you using version 2.6 which is around 5 years old and is no longer supported by the ArduPlane Wiki?
Regards,
TCIII GM
you cant test auto mode at home but you can check with shortest flight like just make small waypoint.
within 5 miter n altitude 3 meter. it will help to get better understanding.
