Can someone please share a link to a previous version of BLheli 32 suite that works with the current stable firmware?
I think the stable release is 4.0.7. The new one only works with the beta firmware, 4.0.10
I am trying to solve a problem and it might be an esc problem or a motor problem.
I am using this esc
The latest version of BLheli does not detect any ESC’s with the beta firmware and the latest version can’t connect through the stable release of the firmware.
I suspect I read about some issue with the Turnigy BLHELI ESCs, I think they were just stopping mid-flight. It could be time to try a different brand and see if you get the same issues.
Xfacta which ESCs do you use? According to the motor manufacturer my motors should pull around 30A with a 12 x 3.8. I am thinking a 50A should give me enough headroom.
I’ve had success with the Holybro Tekko32 F3 4in1 45A and 65A Metal - both have been stress tested (or at least used extensively) without issue. I know when they say “45 Amps” these Holybro 4in1 ESCs are meant to do 45 Amps per ESC channel, so that would be 45x4=180Amps, however that would likely exceed the current capacity of the whole board. Actual specifications are yet to be found.
I know other people have been using the Aikon AK32Pro ESC and there’s probably plenty more reliable alternatives.
I tried another PC and I am a little further now it seems. I am running Mission Planner as admin and also BLHeli suite 32. Maybe that helps someone in the future.
BLHeli suite 32 32.8.0.8 starts and it can connect to Ardupilot running firmware 4.0.7. It connects now at least. I will post another topic about the next step
