Plane launch dolly build with maintaining straight line of launch
Since few months im trying to make motorized rc plane dolly. Its simple three wheel construction with one turning rear wheel
Img: https://imgur.com/a/vaPfrnE
The main idea is to use the dolly to accelerate the plane to take-off speed, meanwhile it should stabilize and maintain straight line of launch.
For now dolly is working fine in manual mode without any stabilization. In final version i want to operate with throttle manually and in the same time autopilot should countersteer rear wheel. I am completly new to ardupilot and i cant find specific flight mode that will work as my needs, maybe someone can help me.
At this point i found that loiter mode is creating virtual line and dolly follows it, but i cant operate with throttle in that mode
Ps. I am using ArduRover 4.5.6
Matek f405 wmn
Matek M10Q GPS QMC5883 Compass
Acro mode will maintain a heading until you steer it otherwise. Let go of the stick and you now have a new heading. You should start in Acro Mode anyway for configuration.
Okay i will give ot a try today, but i remember that ive tested it already. I remember also that in acro i cant slow down, i dont know if it was trying to achieve some cruise speed or something. Can i turn off this option somehow? I want to use throttle only with gimbals
That doesn’t make sense.
Acro mode
If you can try to operate the dolly with Arduplane firmware, I would recommend to use the ground steering function of Arduplane:
https://ardupilot.org/plane/docs/tuning-ground-steering-for-a-plane.html
This keeps the heading on the ground constant up to an adjustable height. It also works without rudder if you have a steerable tail wheel, as you do.
I am impressed by the directional stability. Take-off and landing without any rudder input :
Rolf
Addendum: Perhaps a passive tail wheel on the trolley is sufficient if the aircraft can develop sufficient rudder effect to steer the trolley while it is still on the trolley
