Hi everyone,
I am experiencing an issue where my plane enters a continuous, uncommanded circling/toilet-bowl behavior, but it happens specifically when attempting to roll while flying in AutoTune mode.
Vehicle Details:
- Airframe: fixed wing with span of 158cm, with vtail
- Flight Controller: Matek H743
- Firmware Version: ArduPlane V4.7.0
- PID Settings: Factory defaults / stock parameters
Symptom Description:
I am taking off directly in AutoTune mode as recommended by the documentation for a maiden flight. The takeoff and climb are perfectly normal, straight, and stable. However, the moment I input a roll command to start the tuning process, the plane fails to complete a crisp roll and instead locks into a widening, continuous circling pattern (similar to a toilet-bowl effect).
Because this is happening entirely within AutoTune mode from takeoff to touchdown, I understand that it shouldn’t be a GPS/Compass position-hold conflict.
What I have checked on the ground:
- Manual Mode: Ailerons move in the correct direction with transmitter stick inputs.
- FBWA Mode: Tilting the plane by hand causes the ailerons to deflect correctly to counter the roll (defending the horizon).
- Trims: Transmitter trims are centered at zero. Mechanical surfaces look flush on the bench.
I am unsure if this is a severe aerodynamic stall/adverse yaw issue due to the weak or its too strong factory PID gains, a subtle control reversal I am missing under load, or something else entirely.
I have attached my Dataflash log (.bin file) below. Could someone please review my EKF status, servo outputs, and rate responses during the roll attempts to help me pinpoint the cause?
Thank you for your help!
