Plane 4.6.0 beta
We have just released plane 4.6.0-beta1. This is a major release with a lot of changes. Please look through the list of changes below for details.
There should be no need to backup and restore parameters as part of installing the release onto the flight controller. If issues appear, please report them but also feel free to downgrade back to the stable version (4.5.7).
Happy flying!
  1. Board specific changes
  • AnyLeaf H7 supports compass and onboard logging
  • Blitz743Pro supports CAN
  • BlueRobotics Navigator supports BMP390 baro
  • Bootloader ECC failure check fixed on boards with >128k bootloader space (e.g CubeRed)
  • CB Unmanned Stamp H743 support
  • ClearSky CSKY405 support
  • CUAV-7-Nano default batt monitor fixed
  • CubeRed bootloader fixes including disabling 2nd core by default
  • CubeRed supports PPP networking between primary and secondary MCU
  • CubeRedPrimary supports external compasses
  • ESP32 main loop rate improvements
  • ESP32 RC input fixes and wifi connection reliability improved
  • ESP32 safety switch and GPIO pin support
  • FlyingMoon no longer support MAX7456
  • Flywoo F405HD-AIOv2 ELRS RX pin pulled high during boot
  • Flywoo H743 Pro support
  • Flywoo/Goku F405 HD 1-2S ELRS AIO v2
  • FlywooF745 supports DPS310 baro
  • FPV boards lose SMBus battery support (to save flash)
  • GEPRC F745BTHD support
  • GEPRCF745BTHD loses parachute support, non-BMP280 baros (to save flash)
  • Here4FC bootloader fix for mismatch between RAM0 and periph that could prevent firmware updates
  • Holybro Kakute F4 Wing support
  • iFlight 2RAW H743 supports onboard logging
  • JFB110 supports measuring servo rail voltage
  • JFB110 supports safety switch LED
  • JHEM-JHEF405 bootloader supports firmware updates via serial
  • JHEMCU GF30H743 HD support
  • JHEMCU-GF16-F405 autopilot support
  • JHEMCU-GSF405A becomes FPV board (to save flash)
  • KakuteF7 only supports BMP280 baro (to save flash)
  • KakuteH7Mini supports ICM42688 IMU
  • Linux auto detection of GPS baud rate fixed
  • Linux board scheduler jitter reduced
  • Linux board shutdown fixes
  • MakeFlyEasy PixPilot-V6Pro support
  • MatekF405, Pixhawk1-1M-bdshot, revo-mini loses blended GPS (to save flash)
  • MatekH7A3 support Bi-directional DShot
  • MicoAir405v2 and MicoAir405Mini support optical flow and OSD
  • MicoAir743 internal compass orientation fixed
  • MicroAir405Mini, MicroAir743, NxtPX4v2 support
  • MicroAir405v2 Bi-directional DShot and LED DMA fixes
  • MicroAir405v2 defined as FPV board with reduced features (to save flash)
  • ModalAI VOXL2 support including Starling 2 and Starling 2 max
  • mRo Control Zero Classic supports servo rail analog input
  • mRo KitCAN revC fixed
  • Mugin MUPilot support
  • OmnibusF7v2 loses quadplane support (to save flash)
  • Pixhack-v3 board added (same as fmuv3)
  • Pixhawk6C bootloader supports flashing firmware from SD card
  • RadiolinkPIX6 imu orientation fixed
  • RadiolinkPIX6 supports SPA06 baro
  • ReaperF745 V4 FC supports MPU6000 IMU
  • RPI5 support
  • SDModelH7v2 SERIAL3/7/9_PROTOCOL param defaults changed
  • Solo serial ports default to MAVLink1
  • SpeedyBeeF405Wing gets Bi-directional DShot
  • SpeedyBeeF405WING loses landing gear support, some camera gimbals (to save flash)
  • Spektreworks boom board support
  • TrueNavPro-G4 SPI does not share DMA
  • X-MAV AP-H743v2 support
  1. AHRS/EKF enhancements and fixes
  • AHRS_OPTION to disable fallback to DCM (affects Plane and Rover, Copter never falls back)
  • AHRS_OPTION to disable innovation check for airspeed sensor
  • Airspeed sensor health check fixed when using multiple sensors and AHRS affinity
  • DCM support for MAV_CMD_EXTERNAL_WIND_ESTIMATE (Plane only)
  • EK2 supports disabling external nav (see EK2_OPTIONS)
  • EK3 External Nav position jump after switch from Optical flow removed (see EK3_SRC_OPTION=1)
  • EK3 uses filtered velocity corrections for IMU position
  • EKF2, EKF3, ExternalAHRS all use common origin
  • EKF3 accepts set origin even when using GPS
  • EKF3 allows earth-frame fields to be estimated with an origin but no GPS
  • EKF3 copes better with GPS jamming
  • EKF3 logs mag fusion selection to XKFS
  • EKF3 wind estimation when using GPS-for-yaw fixed
  • External AHRS improvements including handling variances, pre-arm origin check
  • Inertial Labs External AHRS fixes
  • VectorNav driver fix for handling of error from sensor
  • VectorNav External AHRS enhancements including validation of config commands and logging improvements
  • VectorNav support for sensors outside VN-100 and VN-300
  1. Driver enhancements and bug fixes
  • ADSB fix to display last character in status text sent to GCS
  • Ainstein LR-D1 radar support
  • Airspeed ASP5033 whoami check fixed when autopilot rebooted independently of the sensor
  • AIRSPEED message sent to GCS
  • Analog temperature sensor extended to 5th order polynomial (see TEMP_A5)
  • ARSPD_OPTIONS to report calibration offset to GCS
  • Baro EAS2TAS conversions continuously calculated reducing shocks to TECS (Plane only)
  • Baro provides improved atmospheric model for high altitude flight
  • BARO_ALT_OFFSET slew slowed to keep EKF happy
  • BATTx_ESC_MASK param supports flexible mapping of ESCs to batteries
  • BATTx_OPTION to not send battery voltage, current, etc to GCS
  • Benewake RDS02U radar support
  • Bi-directional DShot on IOMCU supports reversible mask
  • Bi-directional DShot telemetry support on F103 8Mhz IOMCUs
  • BMM350 compass support
  • CAN rangefinders and proximity sensors may share a CAN bus (allows NRA24 and MR72 on a single CAN bus)
  • Compass calibration world magnetic model checks can use any position source (e.g. not just GPS)
  • CRSF baro and vertical speeed fixed
  • CRSF RX bind command support
  • DroneCAN battery monitor check to avoid memory corruption when type changed
  • DroneCAN DNA server fixes including removing use of invalid node IDs, faster ID allocation, elimination of rare inability to save info
  • DroneCAN EFI health check fix
  • DroneCAN ESC battery monitors calculate consumed mah
  • DroneCAN ESCs forced to zero when disarmed
  • DroneCAN RPM message support
  • DroneCAN timeout fix for auxiliary frames
  • DroneCAN to serial tunneling params accepts short-hand baud rates (e.g. ‘57’ for ‘57600’)
  • F9P, F10-N and Zed-F9P support for GPSx_GNSS_MODE to turn on/off SBAS, Galileo, Beidou and Glonass
  • FuelLevel battery monitor fix to report capacity
  • GPS_xxx params renamed to GPS1_xxx, GPS_xxx2 renamed to GPS2_xxx
  • Hirth EFI logging includes modified throttle
  • Hirth ICEngine supports reversed crank direction (see ICE_OPTIONS parameter)
  • Hott and LTM telemetry deprecated (still available through custom build server)
  • i-BUS telemetry support
  • ICE_PWM_IGN_ON, ICE_PWM_IGN_OFF, ICE_PWM_STRT_ON, ICE_PWM_STRT_OFF replaced with SERVOx_MIN/MAX/REVERSED (Plane only)
  • ICE_START_CHAN replaced with RC aux function (Plane only)
  • ICEngine retry max added (see ICE_STRT_MX_RTRY)
  • IE 2400 generator error message severity to GCS improved
  • INA2xx battery monitor support (reads temp, gets MAX_AMPS and SHUNT params)
  • MCP9600 temperature sensor I2C address fixed
  • MLX90614 temperature sensor support
  • MSP GPS ground course scaling fixed
  • MSP RC uses scaled RC inputs (fixes issue with RCx_REVERSED having no effect)
  • Networking supports reconnection to TCP server or client
  • OSD params for adjusting horizontal spacing and vertical extension (see OSD_SB_H_OFS, OSD_SB_V_EXT)
  • Relay inverted output support (see RELAYx_INVERTED parameter)
  • ROMFS efficiency improvements
  • RS-485 driver enable RTS flow control
  • Sagetech MXS ADSP altitude fix (now uses abs alt instead of terrain alt)
  • Septentrio GPS sat count correctly drops to zero when 255 received
  • Septentrio supports selecting constellations (see GPS_GNSS_MODE)
  • Single LED for user notification supported
  • SPA06 baro supported
  • Sum battery monitor optionally reports minimum voltage instead of average
  • Sum battery monitor reports average temp
  • Torqeedo dual motor support (see TRQ1, TRQ2 params)
  • Ublox GPS driver uses 64 bit time for PPS interrupt (avoids possible dropout at 1hour and 12 minutes)
  • UBlox GPS time ignored until at least 2D fix
  • VideoTX supports additional freq bands (RushFPV 3.3Ghz)
  • Volz logs desired and actual position, voltage, current, motor and PCB temp
  • Volz server feedback and logging fixed
  • Volz servo output in its own thread resulting in smoother movements
  • W25N02KV flash support
  1. Networking enhancements and fixes
  • Allow multiple UDP clients to connect/disconnect/reconnect
  • Ethernet supports faster log downloading (raised SDMMC clock limit on H7)
  1. Camera and gimbal enhancements
  • Alexmos precision improved slightly
  • CAMERA_CAPTURE_STATUS mavlink msg sent to GCS (reports when images taken or video recorded, used by QGC)
  • CAMERA_FOV_STATUS mavlink reports lat,lon of what camera is pointing at
  • DO_MOUNT_CONTROL yaw angle interpreted as body-frame (was incorrectly being interpreted as earth-frame)
  • Dual serial camera gimbal mounts fixed
  • Lua script bindings to send CAMERA_INFORMATION and VIDEO_STREAM_INFORMATION messages to GCS
  • Retract Mount2 aux function added (see RCx_OPTION = 113)
  • Servo gimbal reported angles respect roll, pitch and yaw limits
  • Siyi driver sends autopilot location and speed (recorded in images via EXIF)
  • Siyi picture and video download scripts
  • Siyi ZT6 and ZT30 support sending min, max temperature (see CAMERA_THERMAL_RANGE msg)
  • Siyi ZT6 and ZT30 thermal palette can be changed using camera-change-setting.lua script
  • Siyi ZT6 hardware id and set-lens fixed
  • Topotek gimbal support
  • Trigger distance ignores GPS status and only uses EKF reported location
  1. Harmonic notch enhancements
  • Harmonic notch is active in forward flight on quadplanes
  • Harmonic notch filter freq clamping and disabling reworked
  • Harmonic notch handles negative ESC RPMs
  • Harmonic notch supports per-motor throttle-based harmonic notch
  1. Copter specific enhancements and bug fixes
  • Attitude control fix to dt update order (reduces rate controller noise)
  • Auto mode fix to avoid prematurely advancing to next waypoint if given enough time
  • Auto mode small target position jump when takeoff completes removed
  • Auto mode yaw drift when passing WP removed if CONDITION_YAW command used and WP_YAW_BEHAVIOR = 0/None
  • Auto, Guided flight mode pause RC aux switch (see RCx_OPTION = 178)
  • AutoRTL (e.g. DO_LAND_START) uses copter stopping point to decide nearest mission command
  • AutoRTL mode supports DO_RETURN_PATH_START (Copter, Heli only)
  • AutoTune fix to prevent spool up after landing
  • AutoTune performance and safety enhancements (less chance of ESC desync, fails when vehicle likely can’t be tuned well)
  • Autotune test gains RC aux switch function allows testing gains in any mode (see RCx_OPTION = 180)
  • Config error avoided if auto mode is paused very soon after poweron
  • FLIGHT_OPTIONS bit added to require position estimate before arming
  • Follow mode slowdown calcs fixed when target is moving
  • Ground oscillation suppressed by reducing gains (see ATC_LAND_R/P/Y_MULT)
  • Guided mode internal error fix when taking off using SET_ATTITUDE_CONTROL message
  • Guided mode internal error resolved when switching between thrust or climb rate based altitude control
  • Guided mode yaw fixed when WP_YAW_BEHAVIOR = 0/None and CONDITION_YAW command received containing relative angle
  • Landing detector fixed when in stabilize mode at full throttle but aircraft is upside down
  • Landing detector logging added to ease support (see LDET message)
  • Loiter unlimited command accepts NaNs (QGC sends these)
  • Mavlink SYSTEM_STATUS set to BOOT during initialisation
  • MOT_PWM_TYPE of 9 (PWMAngle) respects SERVOx_MIN/MAX/TRIM/REVERSED param values
  • Payload place bug fix when aborted because gripper is already released
  • RC based tuning (aka CH6 tuning) can use any RC aux function channel (see RCx_OPTION = 219)
  • RTL_ALT minimum reduced to 30cm
  • SystemID position controller support (Copter and Heli)
  • TriCopter motor test and slew-up fixed
  • WPNAV_SPEED min reduced to 10 cm/s (Copter only)
  • Loiter mode zeros desired accel when re-entering from Auto during RC failsafe
  1. TradHeli specific enhancements
  • Autorotation yaw behaviour fix
  • Autotune improvements including using low frequency dwell for feedforward gain tuning and conducting sweep in attitude instead of rate
  • Blade pitch angle logging added (see SWSH log message)
  • Constrain cyclic roll for intermeshing
  • ICE / turbine cool down fix
  • Inverted flight extended to non manual throttle modes
  • Inverted flight transitions smoothed and restricted to only Stabilize mode
  • SWSH logging fix for reversed collectives
  1. Plane specific enhancements and bug fixes
  • AIRSPEED_STALL holds vehicle stall speed and is used for minimum speed scaling
  • Allow for different orientations of landing rangefinder
  • Assistance requirements evaluted on mode change
  • FBWB/CRUISE climb/sink rate limited by TECS limits
  • FLIGHT_OPTION to immediately climb in AUTO mode (not doing glide slope)
  • Glider pullup support (available only through custom build server)
  • Loiter breakout improved to better handle destinations inside loiter circle
  • Manual mode throttle made consistent with other modes (e.g battery comp and watt limit is done if enabled)
  • Mavlink GUIDED_CHANGE_ALTITUDE supports terrain altitudes
  • Minimum throttle not applied during SLT VTOL airbrake (reduces increase in airspeed and alt during back transition)
  • Q_APPROACH_DIST set minimum distance to use the fixed wing approach logic
  • Quadplane assistance check enhancements
  • Quadplane Deca frame support
  • Quadplane gets smoother takeoff by input shaping target accel and velocity
  • Servo wiggles in altitude wait staged to be one after another
  • Set_position_target_global_int accepts MAV_FRAME_GLOBAL_RELATIVE_ALT and MAV_FRAME_GLOBAL_TERRAIN_ALT frames
  • Takeoff airspeed control improved (see TKOFF_MODE, TKOFF_THR_MIN)
  • Takeoff fixes for fence autoenable
  • Takeoff improvements including less overshoot of TKOFF_ALT
  • TECS reset along with other controllers (important if plane dropped from balloon)
  • Tilt quadplane ramp of motors on back transition fixed
  • Tiltrotor tilt angles logged
  • TKOFF_THR_MIN applied to SLT transitions
  • Twin motor planes with DroneCAN ESCs fix to avoid max throttle at arming due to misconfiguration
  • VTOLs switch to QLAND if a LONG_FAILSAFE is triggered during takeoff
  1. Rover specific enhancements and bug fixes
  • Auto mode reversed state maintained if momentarily switched to Hold mode
  • Circle mode tracks better and avoids getting stuck at circle edge
  • Flight time stats fixed
  • MAV_CMD_NAV_SET_YAW_SPEED deprecated
  • Omni3Mecanum frame support
  • Stopping point uses max deceleration (was incorrectly using acceleration)
  • Wheel rate controller slew rate fix
  1. Antenna Tracker specific enhancements and bug fixes
  • Never track lat,lon of 0,0
  1. Scripting enhancements
  • advance-wp.lua applet supports advancing Auto mode WP via RC switch
  • AHRS_switch.lua supports switching between EKF2 and EKF3 via RC switch
  • battery_internal_resistance_check.lua monitors battery resistance
  • CAN:get_device returns nil for unconfigured CAN device
  • copter_terrain_brake.lua script added to prevent impact with terrain in Loiter mode (Copter only)
  • Copter:get_target_location, update_target_location support
  • crosstrack_restore.lua example allows returning to previous track in Auto (Plane only)
  • Display text on OLED display supported
  • Docs improved for many bindings
  • EFI get_last_update_ms binding
  • EFI_SkyPower.lua driver accepts 2nd supply voltage
  • ESC_slew_rate.lua example script supports testing ESCs
  • Filesystem CRC32 check to allow scripts to check module versions
  • forced arming support
  • GPIO get/set mode bindings (see gpio:set_mode, get_mode)
  • GPS-for-yaw angle binding (see gps:gps_yaw_deg)
  • Halo6000 EFI driver can log all CAN packets for easier debugging
  • handle_external_position_estimate binding allows sending position estimate from lua to EKF
  • I2C:transfer support
  • IMU gyros_consistent and accels_consistent bindings added
  • INF_Inject.lua driver more robust to serial errors, improved logging, throttle and ignition control
  • INS bindings for is calibrating, gyro and accel sensor values
  • IPV4 address bindings (see SocketAPM_ipv4_addr_to_string) to allow UDP server that responds to individual clients
  • Logging of booleans supported
  • Lua language checks improved (finds more errors)
  • MAVLink commands can be called from scripting
  • MCU voltage binding (see analog:mcu_voltage)
  • NMEA 2000 EFI driver (see EFI_NMEA2k.lua)
  • “open directory failed” false warning when scripts in ROMFS fixed
  • Param_Controller.lua supports quickly switching between 3 parameter sets via RC switch
  • Pass by reference values are always initialized
  • pelco_d_antennatracker.lua applet supports sending Pelco-D via RS-485 to PTZ cameras
  • plane_aerobatics.lua minor enhancements
  • REPL applet (read-evaluate-print-loop, see repl.lua) for interactive testing and experimentation
  • “require” function failures in rare circumstances fixed
  • “require” function works for modules in ROMFS (e.g. not on SD card)
  • revert_param.lua supports more params (e.g ATC_RATE_R/P/Y, PTCH2SRV_TCONST, RLL2SRV_TCONST, TECS_)
  • Scripts may receive mavlink messages which fail CRC (e.g messages which FC does not understand)
  • SD card formatting supported
  • Serial device simulation support (allows Lua to feed data to any supported serial protocol for e.g. sensor simulation)
  • set_target_throttle_rate_rpy allows rate control from scripts (new for Copter)
  • sitl_standby_sim.lua example shows how to switch between redundant flight controllers using an RC switch
  • Slung payload oscillation suppression applet added (see copter-slung-payload.lua)
  • Temperature sensor bindings added
  • uint64 support
  • Various performance and memory usage optimizations
  • VTOL-quicktune.lua minor enhancements including increasing YAW_FLTE_MAX to 8
  • x-quad-cg-allocation.lua applet corrects for the CoM discrepancy in a quad-X frame
  1. GCS / mavlink related changes and fixes
  • BATTERY2 message deprecated (replaced by BATTERY_STATUS)
  • CMD_MISSION_START/STOP rejected if first-item/last-item args provided
  • Deny attempts to upload two missions simultaneously
  • Fence and Rally points may be uploaded using FTP
  • GPS_INPUT and HIL_GPS handles multiple GPSs
  • HIGHRES_IMU mavlink message support (used by companion computers to receive IMU data from FC)
  • MAV_CMD_COMPONENT_ARM_DISARM accepts force arm magic value of 21196
  • MAV_CMD_DO_SET_SAFETY_SWITCH_STATE support
  • MAV_CMD_SET_HAGL support (Plane only)
  • MAVFTP respects TX buffer flow control to improve FTP on low bandwidth links
  • MAVLink receiver support (RADIO_RC_CHANNELS mavlink message)
  • Message interval supports TERRAIN_REPORT msg
  • Mission upload may be cancelled using MISSION_CLEAR_ALL
  • MOUNT_CONFIGURE, MOUNT_CONTROL messages deprecated
  • RC_CHANNELS_RAW deprecated
  • Serial passthrough supports parity allowing STM32CubeProgrammer to be used to program FrSky R9 receivers
  • SET_ATTITUDE_TARGET angular rate input frame fixed (Copter only)
  • TIMESYNC and NAMED_VALUE_FLOAT messages not sent on high latency MAVLink ports
  1. Logging enhancements and fixes
  • AC_PID resets and I-term sets logged
  • ANG provides attitude at high rate (equivalent to ATT)
  • ATT logs angles as floats (better resolution than ints)
  • CAND message gets driver index
  • DCM log message includes roll/pitch and yaw error
  • EDT2 log msg includes stress and status received via extended DShot Telemetry v2
  • EFI ECYL cylinder head and exhaust temp logs in degC (was Kelvin)
  • ESCX log msg includes DroneCAN ESCs status, temp, duty cycle and power pct
  • FMT messages written as required instead of all at beginning
  • Logging restarted after download completes when LOG_DISARMED = 1
  • MISE msg logs active mission command (CMD logged when commands are uploaded)
  • ORGN message logging fixed when set using SET_GPS_GLOBAL_ORIGIN
  • RPM sensor logging gets instance field, quality and health fields
  • Short filename support removed (e.g log1.BIN instead of 00000001.BIN)
  • Temperature sensor logging option for only sensors with no source (see TEMP_LOG)
  • UART data rates logged at 1hz (see UART message)
  1. ROS2 / DDS support
  • Airspeed published
  • Battery topic reports all available batteries
  • Compile-time configurable rates for each publisher
  • DDS_TIMEOUT_MS and DDS_MAX_RETRY set timeout and num retries when client pings XRCE agent
  • GPS global origin published at 1 Hz
  • High frequency raw imu data transmission
  • Joystick support
  • Support sending waypoints to Copter and Rover
  • Remove the XML refs file in favor of binary entity creation
  1. Safety related enhancements and fixes
  • Accel/Gyro inconsistent message fixed for using with only single IMU
  • Battery monitor failure reported to GCS, triggers battery failsafe but does not take action
  • Far from EKF origin pre-arm check removed (Copter only)
  • Fence breach warning message slightly improved
  • Fence enhancements incluiding alt min fence (Copter only, see FENCE_AUTOENABLE, FENCE_OPTIONS)
  • Fences can be stored to SD Card (see BRD_SD_FENCE param)
  • ICEngine stopped when in E-Stop or safety engaged (Plane only)
  • LEDs flash green lights based on EKF location not GPS
  • Parachute option to skip disarm before parachute release (see CHUTE_OPTIONS)
  • Plane FENCE_AUTOENABLE of 1 or 2 deprecation warning added
  • Pre-arm check if OpenDroneID is compiled in but disabled
  • Pre-arm check of duplicate RC aux functions fixed (was skipping recently added aux functions)
  • Pre-arm checks alert user more quickly on failure
  • Prearm check for misconfigured EAHRS_SENSORS and GPS_TYPE
  • Proximity sensor based avoidance keeps working even if one proximity sensor fails (Copter, Rover)
  • RC aux functions for Arm, Disarm, E-Stop and Parachute ignored when RC is first turned on
  • Warning of duplicate SERIALx_PROTOCOL = RCIN
  1. Other bug fixes and minor enhancements
  • Accel cal fixed for auxiliary IMUs (e.g. IMU4 and higher)
  • Bootloader fix to reduce unnecessary mass erasing of flash when using STLink or Jlink tools
  • Bootloader rejects allocation of broadcast node ID
  • CAN forward registering/de-registering fix (affected Mission Planner DroneCAN UI)
  • Dijkstras fix to correct use of uninitialised variable
  • DShot rates are not limited by NeoPixel rates
  • Ethernet and CAN bootloader fix to prevent getting stuck in bootloader mode
  • Filesystem does not show entries for empty @ files
  • Filesystem efficiency improvements when reading files
  • Flight statistics only reset if user sets STAT_RESET to zero (avoids accidental reset)
  • Flight time statistics updated on disarm (avoids issue if vehicle powered-down soon after disarm)
  • Internal error thrown if we lose parameters due to saving queue being too small
  • MAVLink via DroneCAN baud rate fix
  • SPI pins may also be used as GPIOs
  • Terrain cache size configurable (see TERRAIN_CACHE_SZ)
  1. Developer focused fixes and enhancements
  • AP_Camera gets example python code showing how to use GStreamer with UDP and RTSP video streams
  • Cygwin build fix for non-SITL builds
  • Cygwin build fixed with malloc wrap
  • DroneCAN and scripting support FlexDebug messages (see CAN_Dn_UC_OPTION, FlexDebug.lua)
  • EKF3 code generator documentation and cleanup
  • GPS jamming simulator added
  • MacOS compiler warnings reduced
  • SFML joystick support
  • SITL support for OpenBSD
  • Text warning if older Fence or Rally point protocols are used
Confirmed working. Sorry for the noise.
Observation during 1st flight with 4.6.0-beta1.
During Takeoff THR stays at 100% while previously when TKOFF_THR_MAX_T was exceeded,
it was reduced to Angle in TKOFF Mission Item divided by TECS_PITCH_MAX.
The Takeoff Level-Off worked on the flight with 4.6.0-beta1 (15-20km/h headwind) but I had another flight with 4.7.0-dev the day before to test TECS_TKOFF_IGAIN=0 (the new active default) and that takeoff leveled out 2 meters below target altitude and did not move on to the next mission item. Just mentioning that there may be an issue.
I’ll do another flight with 4.6.0-beta1, lower angle and hopefully less wind to confirm my theory.
EDIT:
This flight with 12deg climb again leveled out below target altitude but it was possible to raise it above with stick mixing and make next mission item start. I’m in contact with @georacer about this.
Linking GPS Issue from other thread for completeness.
Just a small correction: The new parameter is called TKOFF_OPTIONS, not TKOFF_MODE.
For the record, I’m typing down my findings here: AP_TECS: Fix Regression of TKOFF_IGAIN by menschel · Pull Request #28352 · ArduPilot/ardupilot · GitHub
Just for the record, I also observed an unexpected course correction during takeoff.
The target heading (300) is set when yaw was not yet reset by gps and after it was reset (to 270), the plane dials in on the wrong target heading (300).
was this with TAKEOFF mode or an AUTO takeoff?
If in TAKEOFF mode this PR should fix it:
Auto mode takeoff mission item. I’ll pull and check if it’s fixed.
I may have found a false positive. I’ve been testing with considerable cross-wind. I have to check again with no wind to be sure the course deviation is really present in auto takeoff mission item.
Incorrect Motor Tilt Behavior in QRTL Mode Transition
Description of the Issue:
When transitioning from QLOITER to QRTL, the motors tilt forward unexpectedly, creating an undesired longitudinal thrust vector.
This behavior is not observed when transitioning from QLOITER to QLAND. It appears to be specific to the QRTL mode.
Steps to Reproduce:
Switch to QLOITER mode.
While in QLOITER, initiate a mode transition to QRTL.
Observe motor tilt behavior: motors tilt forward instead of maintaining position.
Expected Behavior: Motors should remain level during the transition to QRTL, unless forward motion is explicitly required by the return-to-launch trajectory.
Actual Behavior: The motors tilt forward, generating longitudinal thrust even when hovering at the current location.
Additional Details:
The issue does not occur in QLAND mode.
It seems related to how _tilt_angle is calculated or updated in ModeQRTL::update() or in the VTOL state management.
Relevant code areas to investigate:
ModeQRTL::enter()
QuadPlane::update_vtol_mode()
QuadPlane::set_vtol_state()
Navigation logic affecting tilt commands during the QRTL trajectory initialization.
Configuration Details:
Firmware: ArduPilot Plane 4.6 beta
4.7 dev all the same
Vehicle Type: Tiltrotor Tri - VTOL
can you provide a bin log link?
Confirmed to be a false positive. No Yaw issue visible in calm conditions.
I pushed PR for the other issues.
Plane-4.6.0-beta2 has just been released. This is a fairly major change from beta1 with a ot of fixes and some new features.
Please read the change log carefully!
  1. Board specfic changes
  • FoxeerF405v2 supports BMP280 baro
  • KakuteH7, H7-Mini, H7-Wing, F4 support SPA06 baro
  • MUPilot support
  • SkySakura H743 support
  • TBS Lucid H7 support
  • VUAV-V7pro README documentation fixed
  • X-MAV AP-H743v2 CAN pin definition fixed
  • AutoTune fix for calc of maximum angular acceleration
  • Advanced Failsafe customer build server option
  1. Plane related enhancements and bug fixes
  • QuadPlane fix for QLand getting stuck in pilot repositioning
  • QuikTune C++ conversion (allow running quiktun on F4 and f7 boards)
  • Takeoff direction fixed when no yaw source
  • TECS correctly handles home altitude changes
  1. Bug Fixes and minor enhancements
  • AIRSPEED_AUTOCAL mavlink message only sent when required and fixed for 2nd sensor
  • CAN frame logging added to ease support
  • CRSF reconnection after failsafe fixed
  • EKF3 position and velocity resets default to user defined source
  • Ethernet IP address default 192.168.144.x
  • Fence autoenable fix when both RCn_OPTION=11/Fence and FENCE_AUTOENABLE = 3 (AutoEnableOnlyWhenArmed)
  • Fence pre-arm check that vehicle is within polygon fence
  • Fence handling of more than 256 items fixed
  • FFT protection against divide-by-zero in Jain estimator
  • Frsky telemetry apparent wind speed fixed
  • Inertial sensors stop sensor converging if motors arm
  • Inertial sensors check for changes to notch filters fixed
  • Real Time Clock allowed to shift forward when disarmed
  • ROS2/DDS get/set parameter service added
  • Scripting gets memory handling improvements
  • Scripting promote video-stream-information to applet
  • Topotek gimbal driver uses GIA message to retrieve current angle
  • Tramp VTX OSD power indicator fixed
As you can see from the list we’ve fixed quite a few issues but a few more still remain so there will certainly be a -beta3.
We very much appreciate any help we can get with beta testing because this is an important stage that helps us ensure a good smooth official release so thanks!
I would guess Plane would be affected by this too.
After a long time of SERVO_BLH_RVMASK not working via the IOMCU, it now works but…
In Copter → Cube Orange using DSHOT via IOMCU → the SERVO_BLH_RVMASK doesnt make sense, I cant logically map it to servo channels or motor positions. It is consistent across reboots though, so it doesnt change more randomly than what it already is.
That is: SERVO_BLH_RVMASK “Channel 1” (bit 0) does not map to Servo1 or motor position A
I’ve raised this with the Copter stream and commented in a related PR. Randy has it on his list.
I flew ArduPlane 4.6 beta 2 today on my VTOL Mini Striver with the QioTek Zealot H743 running PPP networking to connect to an A8 Mini gimbal/camera and Raspberry Pi via the BotBlox “DroneNet” switch. The firmware as generated on the Custom Build Server.
The first flight was a manual takeoff, the second was an auto (VTOL) takeoff, I used RTL/QRTL for both landings.
Everything worked great. Here’s the logs:
https://www.dropbox.com/scl/fi/9ikbhangislfne8n8da8v/log_92_2024-12-23-15-48-40.bin?rlkey=b9z55hrntjzwv56pehiq3k1wr&dl=0
https://www.dropbox.com/scl/fi/n7dx9t8uis73c3kp2l9i6/log_93_2024-12-23-16-10-26.bin?rlkey=2511aiodwaxf4k0i2fadm49oq&dl=0
Are there any resources for running quicktune on an F4?
As designed:
My misunderstanding - this is performing as designed because I didn’t set Q_OPTIONS “respect takeoff frames”.
Another flight with 4.6.0 beta 2. I switched to Auto after I was already flying. The plane was already at 114m when I switched to auto. The plane immediately switched to VTOL mode and started going up, and up, and up …
The first mission item is a VTOL takeoff to 100m. Even though it was already above the takeoff altitude at 114m, the plane just kept going up away above the 100m to 176m before I flipped the switch to FBWA.
Here’s the log:
https://www.dropbox.com/scl/fi/8zqxnnsgblwiwbfmn80xf/00000095.BIN?rlkey=8zhar6a93p9f27ozuo9z23rfc&dl=0
This second log, I switched the mission to use Terrain altitudes and started from Auto from the get go. Good flight here’s the log:
https://www.dropbox.com/scl/fi/2yaewq1q8d51tgievp1qw/00000096.BIN?rlkey=xqfzl852ztevc047fobsh1u2o&dl=0
Arduplane supports the FrSky protocol F.Port 2 (115,200 baud). However, FrSky has renamed the protocol to FBUS and now runs it at 460800 baud (protocol itself is unchanged.
Can F.Port 2 be removed and FBUS be added instead? F.Port 2 is hardly ever used, but FBUS can now be used by almost all current FrSky sensors, receivers, etc. I would also like to be able to use FBUS with Arduplane.
I was also wondering if there was any reason that quiktune couldn’t be used on an F4 ArduCopter. It seems to be mentioned in 4.6 announcements for both firmware variants, but shows up in the custom firmware builder under “Plane” features.
Also, kind of referenced here under Plane - Can a F405 run VTOL-quicktune?
