tridge
(tridge)
January 11, 2019, 2:37am
1
The ArduPilot development team is pleased to announce the first beta of the 3.9.5 release, 3.9.5beta1.
The changes in this release are:
fixed orientation of 2nd IMU for OmnibusF7V2
fixed LEDs on Pixhawk4 and Pixhawk4-mini
fixed safety switch on Pixhawk4-mini
improved robustness of microSD support under ChibiOS
support insert of a microSD after boot but before logging starts
under ChibiOS
added BRD_SD_SLOWDOWN parameter to allow microSD cards to be run at
a lower clock to improve reliability
fixed VTOL takeoff in quadplanes to ignore latitude/longitude in
the mission item and always takeoff vertically
added CubePurple (also known as PH2Slim) builds
added DrotekP3Pro builds
RC protocol decoding for SRXL, SUMD and ST24 extended to all boards including pixracer and ChibiOS-only boards
Happy flying!
tridge
(tridge)
January 11, 2019, 8:48pm
3
yak-54:
ChibiOS: detect stuck I2C bus and clear on timeouts
yes, that change is in this beta. My apologies for not mentioning it in the release notes
moreba
(mohammadreza)
January 13, 2019, 3:29pm
4
Hi
in parametrs " Batt_FS_LOW_ACT" have this options: 0.None 1.RTL 2.lLnd 3.Terminate but in http://ardupilot.org/plane/docs/parameters.html additionaly there is 4.Qland option.
iampete
(Peter Hall)
January 13, 2019, 3:45pm
5
could be one of two things,
Your not on the latest mission planner so your param descriptions are not up to date.
The wiki descriptions are built off master so maybe that option is not in the stable release yet.
moreba
(mohammadreza)
January 13, 2019, 7:49pm
6
my mission planner is up to date.
tridge
(tridge)
January 15, 2019, 3:39am
7
Use control-F then the “param gen” button. Then wait four minutes, then restart MissionPlanner. That should get you the new parameter docs.
Cheers, Tridge
tridge
(tridge)
8
I have released 3.9.5beta2, with the following changes over beta1:
fixed EKF yaw reset in quadplanes
fixed bug handling corruption of DSM RC protocols
fixed internal amber LED on CubeBlack
Happy flying!
tridge
(tridge)
January 27, 2019, 6:14am
9
I’ve now released the final version of 3.9.5. The total list of changes for this release over 3.9.4 is:
support insert of a microSD after boot but before logging starts under ChibiOS
added BRD_SD_SLOWDOWN parameter to allow microSD cards to be run at a lower clock to improve reliability
fixed VTOL takeoff in quadplanes to ignore latitude/longitude in the mission item and always takeoff vertically
fixed CAN on Pixhawk4
fixed stuck I2C bus on ChibiOS (affects some airspeed sensors)
Happy flying!
Jan_Willem
(Jan Willem)
February 2, 2019, 7:32pm
10
Hi all,
I’m running an Omnibus F4 v3 controller on a small wing. Firmware version is AP 3.9.5.
I’ve set THR_MIN at 25%. When I engage FBWA with throttle stick down the motor starts running.
I checked this in Mission Planner Tuning screen and when engaging FBWA it appears THR_MIN is output to my throttle channel.
I’ve always assumed throttle has full manual control over the entire range in FBWA flight mode.
Is this supposed to happen?
Best regards,
Jan Willem
The Netherlands
Aticof
(Atico)
February 15, 2019, 7:09am
11
I have installed 3.9.5 NuttX on my VTOL tricopter & Pishawk2.1 but sometimes testing at home with a minimum number of satellites reached and no red messages on HUD, appears on the messages tab “EKF yaw reset …”
