My question is: can Serial 4, ie the FrSky, port on Pixracer be configured to accept a GPS unit?
I’m running ArduCopter v3.5.7 and cannot connect a GPS to Serial 4 although the serial mapper indicates I can configure Serial 4 to be a MavLink port, GPS, FrSky, etc.
Thanks fnoop! It does. From the data sheet for the inverter http://www.ti.com/lit/ds/symlink/sn74lvc2g86.pdf it looks like if I set the “FrSky INV” signal low from the STM chip, then the inverter should hopefully act as a pass through. I’m going to see if I can track down where that pin is set in the software -
