Hi everyone,
I am currently working on an electronic design involving a Pixhawk Cube flight controller, and I need some clarification regarding the TELEM port cable specifications.
From my understanding, the TELEM port uses a JST-GH 6-pin cable, but I would like to confirm the following:
What is the exact wire type used in standard Pixhawk TELEM cables?
(e.g., silicone insulated, PVC, stranded tinned copper, etc.) -
What is the typical wire gauge (AWG)?
Is it usually 28 AWG or 26 AWG? -
Are there any official specifications or recommended standards for these cables (temperature rating, voltage rating, insulation type)?
What is the correct name/keyword to search for this cable or wire online?
(For example: “30 AWG silicone wire”, “JST-GH telemetry cable”, etc.) -
Where can I reliably source this type of wire or pre-made cable for custom hardware design?
For reference, I am considering using 30 AWG silicone insulated wire for signal lines due to flexibility and space constraints.
Example of wire I am referring to:
Typical specs I found:
Silicone insulation (high flexibility)
Tinned copper conductor
Temperature rating up to ~200°C ()
Voltage rating around 600V ()
I would appreciate guidance on whether this is suitable for TELEM/UART signals and best practices for such designs.
Thanks in advance!
