Hello
I have a quad with pixhawk and the external GPS 3dr.
Everything work fine until now with the last firmware and missionplanner, this software are working with W7 64 bits.
when i try to boot the system, start the melody and then stop , with 2 tones , checking webpage for that it’s a Start up Failed.
I enter on CLI, and run tests all give me this output.
tests: reading data unaligned…
tests: directory listing ok (FS mounted and readable)
[file] PASS
[mtd] STARTING TEST
tests: file /fs/mtd_params not found, aborting MTD test
i check the directory /bin and all files have 2 bytes size.
I change the SD card 1rst was a 4Gb and now 8 Gb formated with FAt32
I already try different version of firmware, and all give me the same error.
Thanks very much for your help, and all effort for this project work.
Pedro
