I’m doing some analysis of flight performance on the Pixhawk running the stock Y6 code and am having trouble viewing certain .bin files on the SD card in ~/APM/LOGS. Using the .bin to .log tool in MP works fine for some, but not others. With these same files, I cannot transfer them off the SD card as Windows sees a fatal error. Is there a known issue with Pixhawk saving logs to the SD card?
On a related note, I am having trouble connecting via the MP terminal to the Pixhawk. I can do this with the APM just fine. Should I be using the APM option or PX4/Pixhawk to connect?
