Pixhawk on Trex 500
Hi guys trying to figure out why the ESC is beeping continually. I can’t get any throttle at all. Followed the APM version of set up but nothing. Can arm no problem at all. Put the esc into channel 8 on the pixhawk and can move swash plate and all controls fine,alsoUsing aurora 9 transmitter.
Been thought the set up in planner everything is ok but no throttle and still the beeps from esc. Any help would be great. Thanks Austin.
Hi, have you set the H_RSC_MODE parameter to 1 or 2?
Maybe that’s my problem. Thanks I didn’t know I had to set that lol cheers. Will update when I can. Thanks rob
Maybe that’s my problem. Thanks I didn’t know I had to set that lol cheers. Will update when I can. Thanks rob[/quote]
hi rob ive st it to 2 (set point) now,is this correct I fly mode 2 so not completely sure this is correct. any help would be great. thanks austin.
Either mode is correct, depending on how you want to control it.
If you set it to 1, then it will pass through whatever PWM your radio is outputting on Ch8.
If you set it to 2, then it will send whatever value you have on the RSC Setpoint parameter.
