Good morning
Hopefully you guys can help me figure this out. It may be an equipment compatibility issue iv read conflicting reports thus far.
Equipment :
TX : JR 9303
DSM2 Airmod 2.4 ghz module
AR7010 receiver
Spectrum 9645 Satellite receiver.
The only failsafe function I really need is to cut the throttle should the RC link be lost.
The failsafe feature appears to work if I use the spectrum receiver and a simple servo. (not using pixhawk) when I turn the transmitter off the throttle is cut.
If I install the satellite through the dsm2 port into pixhawk nothing happens when turning the transmitter off. Seems to just hold last known position on all channels including throttle.
If I connect the satilite to the master rx and connect that to the ppm encoder and provide a signal to pixhawk that way failsafe works.
I would really rather move to the satilite only solution as its much simpler and has 1/3 the number of components. Is it possible to do so a retain failsafe function with my current TX. Do I need a new receiver?
Thanks for the help
Steven
