I think it just times out, is there a way to read/set the values?
Yours Simon M
Yours Simon M
Hi Simon,
Try this procedure:
copter.ardupilot.com/wiki/initia … elerometer
If this is not working you can try to test the accelerometer in terminal by:
test
ins
Also it’s possible to calibrate it from the terminal by:
setup
accel
Many thanks for your reply.
I had been trying that procedure but it wouldn’t let me finish before it said calibration failed!
However the problem has gone away now. completely removed APM Planner & mission planner, all USB drivers, removed and reformatted the SD card, then started from the beginning.
Now I just need it to arm!
Yours Simon M.
