Pixhawk Cube Black USB-Port
Does anyone know if the USB port next to I2C can be use as a Telemetry UART? From the pinout diagram doesn’t look like, but I thought I should ask.
I am using OSD on one Telemetry-2, ELRS on Telemetry-1 for RC and Yaapu and I wanted to use the ELRS AirPort for GCS.
Any suggestions?
No, you can’t use the USB port as a UART. But you could use one of the GPS ports if you aren’t using both of them.
Great! so I can convert GPS-2 UART as Mavlink?
Yup. GPS and Telem ports are all just UARTs. You can use them however you want.
