Hello everyone,
I want to ask, if there is some kind of procedure to test if Pixhawk is physically fine. In past days I received multiple failure messages and now I am little bit scared. I want to be 100% sure everything is ok.
It all started with “Baro not healthy” message". I wasn’t sure, if it is HW error, temperature was around 0° C, so there might be other reason for this message. I found that recalibration might help to solve the problem. I decide to update firmware to 3.2 and in process recalibrate compass. After that I start getting failure messages “Alt disparity” and “Compass not calibrated”.
I decided to reset Pixhawk to factory setting, but I didn’t find any guide to that. So I did it by pushing reset button on side (one without microUSB) of Pixhawk, until it start blinking blue, and then pushing second reset button next to micro USB on opposite side. Then I installed APM:Plane firmware and after that APM:Copter 3.2, after that I load “IRIS with gimbal” parameter list, calibrated Compass, Radio, Accelerometer and then successfully armed IRIS.
Second day, I took IRIS outside to do autotune, but I keep geting failure messages “Bad velocity”, “Gyro cal. failed”, “high GPS HDOP”. Temperature was again around 0°C.
“Bad velocity” - Accelerometer calibration was successfull, at home in room temperature was everything alright.
“Gyro cal. failed” - I was inserting batteries really gently, like 100 times before. I removed this message on 3rd battery reconnection.
“high GPS HDOP” - this might caused by different place, I noted just to describe whole picture.
After all I was able to make 2 short, not very confident, flights, but I am not sure, what to do next.
Is it safe to fly it? Is Pixhawk temperature sensitive? Should I just calirate Accelerometer again? Is it possible to test Pixhawk HW?
Thanks, Tomas
