Just a question and update. I power my pixhawk with the 3DR power module . But let’s say I want a backup power in output rail or I am running 6S. Here is the problem and I tried this on BOTH of my Pixhawk units. If you power just from output rail the unit switches from Green to Yellow with a low voltage alarm. I am putting 5 volts into the output rail. The HUD tells me it’s only 4.1 volts. Same thing if you power from both the 3dr PM and the output power and cut the 3DR power. It’s stays on but alarm trips. Does the output rail need more the 5 volts input? I am concerned that if I lost the 3DR PM in flight would the alarm trip and Quad lose power? Also, I have 2 vehicles on 6S and want to power with a BEC since the 3dr power module handles 4S max. Any suggestions?
Thanks JEFF
