Pixhawk 6X + T-Motor Cine55C 8-in-1 (BLHeli_32) — DShot wiring for a quadcopter
Hi everyone,
I’m building a professional inspection quadcopter (4 motors, AUW ~2 kg, 6S) and I’m at the electronics integration stage. I’ve read the ArduPilot DShot documentation and found the thread Pixhawk 6x mini wiring DSHOT ESC which is close to my situation, but I still have uncertainties before connecting anything.
Hardware stack:
  • Flight Controller: Holybro Pixhawk 6X (with IOMCU)
  • ESC: T-Motor Cine55C 8-in-1, BLHeli_32, 3–6S, 55A per channel
  • Motors: iFlight Xing2 3110 900KV 6S — only 4 motors used (standard X quadcopter frame)
  • Battery: 6S LiPo (test) / 6S Li-ion (final)
  • Firmware: leaning toward ArduPilot, not yet flashed
What I understand so far (please correct me if wrong):
  1. DShot only works on FMU PWM OUT (AUX 1–8), NOT on MAIN OUT — confirmed by ArduPilot docs
  2. The T-Motor Cine55C signal connector has 10 pins: C (GND), T (telemetry), 1–8 (motor signals)
  3. FC is powered separately via Holybro power module — never from the ESC
  4. Only ONE GND connection between ESC pin C and the FC — not duplicated
My specific questions:
  1. Which 4 signal pins to use on the ESC? The Cine55C has 8 signal outputs (pins 1–8) but I only have 4 motors. Should I use pins 1–4, or is there a specific recommended mapping for a quadcopter?
  2. Which FMU AUX outputs on the Pixhawk 6X? For a standard X quadcopter in ArduPilot, which AUX outputs (1–8) should I connect my 4 ESC signals to? And how do I set the SERVOx_FUNCTION parameters accordingly?
  3. Adapter cables — are they mandatory? The Pixhawk 6X uses JST GH 1.25mm connectors, the T-Motor Cine55C uses 2.54mm servo-style pins. I don’t have adapter cables yet. Is there any way to connect without them, or are JST GH to 2.54mm adapters strictly required?
  4. DShot speed: cable runs under 20cm, BLHeli_32 ESC. DShot300 or DShot600 recommended?
  5. Any known issues with the T-Motor Cine55C 8-in-1 on ArduPilot with only 4 motors connected?
Thanks a lot. Happy to share photos of the setup once wiring is done.
Not so, but use the Aux ports anyway and plan on configuring for bidirectional Dshot.
  1. Use any of the 8. 1-4 of course makes sense.
  2. Use any of the 1st 6 FMU outputs. 1-4 makes sense.
  3. Make whatever cables you need with the cables you have on-hand. Splicing and/or re-pinning the connectors.
  4. Dsho6 600. Again, flash the Bdshot firmware to the flight controller and configure for Bdshot.
  5. I can’t think of any.
Refer to this Arducopter board specific Wiki page for general info Pixhawk 6X
