Hello everyone, this is my first time working with Pixhawk. I connected it according to the scheme, but I ran into a problem, the servos do not work, I measured the voltage of 5v supplied. Also, the motors do not give a ready-to-start signal. Can you please see the schematics, is everything connected correctly? What did I forget?
Hey, I actual plan to build my first self-build quad. The Pixhawk 6c mini flight controller seems to be a not-bad-choice. I’m not the building-expert and more a technical guy. Did you solved your problem with the Pixhawk 6c in the meantime?
Hey Chris,
Yes, I’ve already solved the issue with the Pixhawk 6C — everything works fine now! In fact, I’ve since upgraded to much more powerful motors because in my region we often face extremely strong winds.
You can check out my newer posts on my profile here on the forum — I’ve shared the latest setup and progress there.
Good luck with your first build — feel free to ask if you have any questions!
Hey mate, how did you solve the problem. I wired my electronics as shown in the picture, but when I want to test my motors, the do not move. Any suggestions? Thank you in advance ![]()
