How stable flights does this controller diliver (compared to Dji)? E.g A Holybro x500 model
Also, what altitude can it fly safely.
I have seen some videos and to be honest am not very confident on that matter.
If you got a Holybro X500 kit then the components should be well matched.
Following the proper tuning process should give you better attitude control and stability than a similar DJI.
Do you mean what altitude above home can it go to after launching? In most countries this depends on laws and your licensing too, but technically battery capacity and take off weight are key.
Or do you mean what is the altitude above mean sea level that it can operate?
Hi Shawn,
I was just trying to compare Dji and Holybro. You gave me what I wanted, the right
balance between propeller,motor, battery and total drone weight, as well as proper
balance (motor, esc) is key.
Tks
so…as mentioned by xfacta if you will properly tune your drone the flight will be like DJI.
Just consider that DJI its a close firmware after few time you must change your drone while ardupilot it’s an open source so every release have a bug fix and many improvements.
Low KV for motors… big props and a good batteries
Our company provides a service to tune the copters so that they excel DJI performance. PM me if you are interested.
Amilcar,
Maybe … Please send contact (email)
Tls
