mr_byte31
(mr_byte31)
October 23, 2024, 4:27pm
1
I bought a used Pixhawk 2.4.8 from internet for $10 and it seems to work.
It didn’t come with any external modules ( safety switch, GPS, buzzer,…etc). I had some spare parts to be used but not for GPS. The compatible GPS module on Aliexpress costs $45.
I have HGLRC M100-5883 GPS which contain Ublox M10 + compass.
is there anyway to make my M100-5883 GPS work with pixhawk ?
you will need to adapt the wiring and connect it to a serial and i2c port using JST PH1.25 connectors.
I normally buy those connectors prewired as crimping them isnt easy.
https://www.ebay.co.uk/itm/194163776964
mr_byte31
(mr_byte31)
October 23, 2024, 4:37pm
3
Many thanks …
So I need to buy 4 pins and 6 pins JST 1.25mm sockets and make the wiring and that’s it ?
There is no need to worry about different voltage levels or protocols ?
no the voltages and protocols are all standard so it should work, just remmber you connect the GPS TX to the flight controller RX and RX to the TX.
mr_byte31
(mr_byte31)
October 23, 2024, 4:51pm
5
Perfect and many many thx
I give it a try and i would let you know…
Hello @mr_byte31 ,
I’m also interested on this gnss module.
How did it go, did it work?
Thanks
mr_byte31
(mr_byte31)
November 3, 2024, 9:42pm
7
I ordered some wires from Aliexpress and waiting for them to come.
stay tuned …
