hi all,
i am facing a problem pulsing green light Disarmed )( in pixhawk 2.4.8 how to fit into solid green light(solid green light).
I think what you are looking for is changing the parameter NTF_LED_OVERRIDE
Specifies the source for the colours and brightness for the LED. OutbackChallenge conforms to the MedicalExpress (2018 Medical Express – UAV Challenge) rules, essentially “Green” is disarmed (safe-to-approach), “Red” is armed (not safe-to-approach). Traffic light is a simplified color set, red when armed, yellow when the safety switch is not surpressing outputs (but disarmed), and green when outputs are surpressed and disarmed, the LED will blink faster if disarmed and failing arming checks.
0 Standard
1 MAVLink
2 OutbackChallenge
3 TrafficLight
there’s another parameter to turn down the brightness also
NTF_LED_BRIGHT
Value Meaning
0 Off
1 Low
2 Medium
3 High
