Pixhawk 2.4.8 (clone) want update to 4.0
Will the pixhawk clones be update to firmware 4.0
Having problems updating
Yes, no problem updating.
I’m having a problem, I follow the steps in MP ,
Select x quad frame and then I have to select the board type and I have tried pixhawk1 , fmu2 and fmu3 and the results are the same , it downloads the firmware , I unplugged pixhawk click ok and plug it Back in and it searches for comport and I get ERROR - No Response from board,
I am able to connect board to my computer through the comport
Any reason from not being able to update
Try with QGroundControl. Select these settings:
QGC update
After that connect with Mission Planner if that’s what you want to use.
Thanks a lot.
That worked
Cool. And if you didn’t have fmuv3 now you do.
