Does anyone here experience that I always need to calibrate the ESC in order to arm my quadcopter? Or am i missing something like theres no need to calibrate i just need to on some things like what? Thank you.
Can you provide some more information, e.g.
-Which escs are you using?
-Are you getting a message somewhere that says the escs require calibrating ?
-Or are you assuming they require calibrating because they are beeping?
Thanks
I would try try rebinding the tx/rx.
Hello, I using 30A ESC and A2212 1000KV. Im using mission planner where I install the 3.4 version of firmware and calibrate all the necessary things like frame type, accel ESC. Upon starting to throttle the drone started going up a little bit at the middle of the throttle and its drifting supposedly it should be steay as i tried to hover. What Am I missing?
I have been see you posts so many times,你特么中国人吧。
No Im not chinese. You are.
你可拉倒吧。。。。。。。。。。。。。。。
