I was using pixfalcon on my 62cc gas engine.I mounted it on a damped box with 3M double sided tape.When I reviewed the log it shows extreme vibration in Z axis. X and Y were fine.I attached the log graph of vibration.
What do you think I should do?
They are so small and light, try adding weight to it. Get a small lead sinker used for fishing, flatten it with a hammer and stick it to the pixfalcon.
Thanks for your reply.I was thinking about it.
If you stick the lead weight to the underside, there’s plenty of space on top for a I2C OLED display without covering the main LED.
