Pitching motion when increasing throttle
The copter is doing unwanted pitching motion towards one side only by increasing the throttle. Please suggest how can I overcome this issue.
Is this the same issue discussed Spinning drone caused by yaw imbalance and miss-configuration [solved] - #7 by amilcarlucas ?
If yes, please do not double post, keep it in that thread.
No sir, but this issue is resembling with our pitching issue. Can you just help me to solve the problem
The solution is the same as posted in the other thread. Use the software I told the other user to use.
Ok sir I will do the same process.
