Pilotix H743 Firmware
Hey, perhaps someone can help me with the following connection issue? I bought a Pilotix (H743) flight controller, assuming it was compatible with ArduPilot firmware—which turned out to be a mistake. Unfortunately, there was no support from the manufacturer, and I spent ages experimenting across Linux, Windows, and Cube Programmer to find a firmware target that would at least allow it to boot (Aocoda-RC H743Dual). However, it consistently refuses to connect to Mission Planner, even though tools like ArduPilot Bootloader DFU Loader are able to connect to it. I believe I’ve ruled out the usual driver issues. Could someone perhaps help me narrow down the problem based on the following connection log?
Timeout waiting for autoscan/no mavlink device connected
bei MissionPlanner.MainV2.<>c__DisplayClass124_1.b__6(IProgressReporterDialogue sender) in C:\Users\mich1\Desktop\CubePilot\MissionPlanner\MainV2.cs:Zeile 1495.
bei MissionPlanner.Controls.ProgressReporterDialogue.RunBackgroundOperation(Object o) in C:\Users\mich1\Desktop\CubePilot\MissionPlanner\ExtLibs\Controls\ProgressReporterDialogue.cs:Zeile 111.
Thanks
To what end if the Flight Controller is not supported? What is Mission Planner going to do for you?
Did you try this firmware? Aocoda-H743
And what about these Pilotix FC’s? A couple of them look like clones of Matek boards.
Hi Dave, thanks for your reply. I’m not sure if I understand your question correctly — are you suggesting abandoning the project? That’s not an option for me yet. After all, the non-functional Ardupilot firmware is being distributed by Pilotix sales (hobbydrone cz). From the outside, the board they sell looks like a 100% copy of the Aocoda board, though I only realized that recently.They market it as being manufactured in the EU, which is highly questionable in my view. I wanted to configure the settings using MP. Right now, the board doesn’t have any working firmware at all; even Betaflight isn’t working. Yes, the firmware you mentioned is exactly the one I currently have installed.
That’s not the right path to take to get a new Flight Controller ported:
Porting
Pilotix has their own website, perhaps you can suggest to them that they follow the process?
The manual says this:
Firmware: In the configurator, look for the target PILOTIX_H743 or MATEKH743.
Dave, I have 100% the same opinion :slight_smile:
I wasn´t thinking about getting it “ported”, as this is job of pilotix people, but trying to get this one controller running somehow even if this is only 90% for the moment. Its current status is e-waste.
So still a little help would be desired.
No joy with Matek H743?
I ´ve flashed Matek H743 target again, booting seems ok but still no connection to any AP GCS (failed Mavlink communication). This is the last error log:
Die Sequenz enthält keine Elemente.
bei System.Linq.Enumerable.Aggregate[TSource](IEnumerable1 source, Func3 func)
bei MissionPlanner.MAVLinkInterface.OpenBg(IProgressReporterDialogue PRsender, Boolean getparams) in C:\Users\mich1\Desktop\CubePilot\MissionPlanner\ExtLibs\ArduPilot\Mavlink\MAVLinkInterface.cs:Zeile 960.
@Marc_R Someone has to produce the firmware for this board. That’s it’s, nothing else to consider. If they are not willing to contribute you simply have an unsupported board. Stating “Ardupilot ready” or some such bullshit is meaningless.
Is this the FC? I see they provide 4.7.0 .hex files in Download section, also hwdef.dat files for your build.
Its not that board. That wing board looks like a clone of the Matek Wing board.
If its the Pilotix H743-SLIM, then that looks like a component for component clone of the MatekH743-SLIM V3 from the picture
It does indeed. I think he has a different FC than the Slim. Pilotix has been unresponsive to questions about firmware targets for these boards so they remain in the Unsupported category. When a board is Supported the firmware can be found in the Ardupilot repository not some cloners website. Although to be fair Cloners may not be accurate.
Or perhaps they are in the process of adding their boards:
Partizan>Pilotix
This is the Board I have: FC Pilotix H743 BMI270 | HobbyDrone.cz and it looks like a clone of Aocoda RC H743 Dual
Yea. Partizan>Pilotix need to do work on adding the firmware.
@Ruslan991
…on above mentioned webpage they offer/linked lots of firmware for this board also (Beta & Ardu) but all of them are not working! I think the are in the process of adding
Let’s see if he responds.
I understand! Just answering question of Satoru_Sasaki
In process stuck at 13AUG
Good to confirm the FC. Given the photo is the exact same as Aocoda RC H743 dual, I thought it is rebranded/OEM of it, but provided firmware contains board_id 1251, not Aocoda RC H743 dual’s 5210. So Pilotix is trying to provide their own I guess.
I do have a few Aocoda H743 dual, working fine. Out of idea..
Hi All, I’d like to add the following to the topic — I came across this yesterday:
Introducing the D-H743 30.5mm dual-IMU flight controller .
This is really strange; we have three identical boards from three different manufacturers now (one of them seated in Europe??). Everyone may draw their own conclusions from that…
