PILOT_SPEED_UP/DN limit
What’s the reason for PILOT_SPEED_UP/Down limited to 500 cm/s?
Its not limited, just the recommend range. Higher numbers will work fine.
What’s the trick to configure it? I know many Parameter ranges are recommended yet they will be accepted. Can’t get this one over 500.
OK, QGC saved it and it stuck.
