Persistent Oscillations on 7" Build
I am experiencing oscillations on my 7-inch quad, and I am looking for guidance on how to diagnose and correct the issue. Below are the hardware details:
  • Frame: Axis Manta 7"
  • Motors: V2808 1500KV
  • Props: HQ 7x4.5
  • ESCs: Tekko AM32 45A
  • Flight Controller: Pixhawk 6C Mini
  • Power Board: PM06
  • GPS: M10
  • Battery: 2200mAh 6S When the Quad takes off I see noticeable oscillations during hover and forward flight. I am unsure whether the cause is inadequate PID values, filter configuration, mechanical vibration, or something else. I have not been able to resolve it through basic parameter adjustments.
I would appreciate any suggestions on troubleshooting steps, recommended starting PID values for a build like this, or whether I should capture and share a log for review.
Thank you for any assistance.
Follow these instructions
Also “Battery: 2200mAh 6S” is a bit much I would try S4 until you get it worked out.
Thank you sir, i will try and share the results here
Quick note, with any request for help you will need to upload a .bin file
