PC3000H SkyRC charger + Tattu 3.0 smart battery — need 30-second CAN capture to reverse-engineer proprietary handshake (emulating 14S battery with Arduino Due)
Hi @CraigElder and anyone running a PC3000H with a Tattu smart pack,
I’m emulating a Tattu 3.0 smart battery(or any smart battery) on an Arduino Due + TJA1050 to make a PC3000H Quattro charger recognize it and display cell voltages. Three weeks in. I’ve had one brief success (LCD showed 3.80 V in 4 cell positions once) then nothing since.
What I need: a 30-second CAN capture of a real PC3000H charging a real Tattu 3.0 pack, starting from charger power-on. That single log would close the last gap. I don’t own a Tattu battery.
Setup: Arduino Due + TJA1050, 1 Mbps, 29-bit extended. Dumb 14S pack on the power terminals so the charger sees voltage, no BMS present.
Main CAN IDs on the bus (passive sniff):
0x0010001000 ZFKJ handshake (5A 46 4B 4A …) charger → battery
0x00109216 charger query (FF FF FF FF FF FF FF FF)
0x00109274 our node’s response (DTID 0x1092, node 0x74)
0x01A5A5A5 beacon (A5 D1 D2 D3 D4 D5 D6 5A)
0x00E416E4 charger internal balancer ADC
0x07380F00 charger pack ADC
0x18FF50E5 charger status (always 03 01 19 1B — never changes)
0x1724040B J1939-style A1 query, SA=0x0B → DA=0x04
0x01E0959 battery heartbeat (56 31)
0x01109216 real Tattu broadcast (from public captures)
What I’ve achieved:
  • ZFKJ handshake fully replicated (charger sends 5A 46 4B 4A 83/80 ..., we echo correctly)
  • Cell frames sent on the IDs the charger uses, both byte orders tried
  • One brief LCD hit: 3.80 in 4 positions when we sent 0E D8 (3800 mV) in a byte pair. Never reproduced.
  • Charger’s status byte 0x18FF50E5 never leaves 03 01 19 1B — it never transitions to “battery present”
What I still need to know:
  1. What frame(s) does the charger read for cell voltages?
  2. Does the charger require a chemistry byte (LiPo / LiHV) from the battery?
  3. Does 0x18FF50E5 change when a real battery is connected?
  4. Do cell voltages appear on the LCD before the user presses START?
The ask: any log format works — candump -L, SavvyCAN, text. Even 20 seconds. Ideally starting at charger power-on so I can see the initialization window.
If anyone has both devices and 2 minutes to spare, this unblocks weeks of work. I’ll share the working emulator code once it’s done.
Thanks.
