Hey, I would like to use a 3-way switch on a radio, for example, like on the Taranis x9d.
So let’s assume I have a switch that’s connected to channel 5 on the radio and has 3 PWN values (LOW, NEUTRAL, HIGH), how do I pass these PWN values to an AUX pin on the Pixhawk? let’s say, RC9.
From what I’ve read, in order to enable passthrough, the PWM has to be 1800 micro-sec.
Any suggestions?
Main goal:
The 3 PWN values need to be analyzed by an Arduino Nano . When the PWN value is LOW , the Arduino will drive a DC motor counterclockwise.
When the value is neutral, the motor won’t spin. When the PWM value will be HIGH , the motor will spin clockwise.
Maybe there is a simpler way to do the following, would love to a different solution.
