Hi. I am using an APM 2.6, rangelink 12 channel UHF receiver. APM is running 3.1.1
I am using all 8 inputs to control my full house plane/flight mode. I would like to use the 9th channel, but cannot figure it out. In the parameters, there are no RC9 parameters. There are 1-8, 10, and 11.
RC9 does not exist. When I change RC10_function to 1 (passthough), and plug into pin A1 or A2, there is no servo input.
I cannot run a cable from the rangelink to the pan servo as the receiver is way out on the wing (running ppm input to keep weight down).
How do I get either RC9 or RC10 working for passthough onto the analog pins?
Thanks
Here is my channel layout:
1Aileron (L)
2Elevator
3Throttle
4Rudder
5Flap®
6Flap(L)
7Aileron (L)
8-Flight mode
9-pan.
I would also like to move channels around so I have an osd switch on channel 8 (minim extra osd requires channel 8 for osd switch). Can flight mode be moved to a different one?
I have decided to try to condense the flaps onto 1 input channel. I have been reading the documentation and other people doing it. I do not need APM to give me automatic flaps, just manual flaps.
Is it capable to taking input 5, and splitting into output 5 and output 6, with one of the outputs being reversed. RC#_function doesn’t seem to allow remapping like that.
I think Flap_in_channel and flaperon_output are how I could do it.
