I have configured VTX_BAND, VTX_CHANNEL, and VTX_POWER in OSD 5 for OSD stick command changes. My sticks do not manipulate the menu when in OSD 5 screen. I have the first parameter flashing, but cannot go up, down, or right with right stick (either stick). Any idea what the issue may be? Params linked below. Thanks in advance.
So it’s sprung throttle and I just figured out that throttle channel must be zero to enable right stick navigation. However the Agent Lite LUA is what I really want working, and I’m still unable to change the VTX params from there.
Agent lite has no knowledge of the parameters it is changing - so it must be something to do with the range or type or something similar - what did you set these to when you setup the parameter?
