I made all the necessary settings and calibrations, and the flowX is identical to bodyX, same for Y axis along with gyros. FLOW_POS_X,Y,Z + Lidar are verified.
When I hover in indoor (texture floor), there’s still a drift on loiter mode.
I try to tune PSC_VEL_xx param but it still drift out of it position.
FLOW_FXSCALER,-450 # Inflight Calibration will give good result
FLOW_FYSCALER,-450 # Inflight Calibration will give good result
FLOW_ORIENT_YAW,0
FLOW_POS_X,-0.128
FLOW_POS_Y,0
FLOW_POS_Z,0
FLOW_TYPE,11 # no such number
RNGFND1_TYPE,38 # why 38 NoopLoop_TOFSense_CAN, external RNGFND??
INS_HNTCH_ENABLE,0
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0 #consider checking your UA noise/vibration level
LOG_FILE_DSRMROT,1 # consider log each flight separately
MOT_PWM_MAX,2000 #consider to find out ESC/Motor PWM range
MOT_PWM_MIN,1000 #consider to find out ESC/Motor PWM range
put back to the default first. do it after inflight optical flow calibration if needed.
My guess is you have not done Quiktune and Autotune yet.
Thank you. I custom OpticalFlow driver to receive Micoair protocol for both RngFnd and OpticalFlow, This is my new device ID (FLOW_TYPE=11, and RNGFND1_TYPE=38)
I tried Inflight Calibration but result are “no better scalar x and y” so I manual adjust FLOW_FXSCALER and FLOW_FYSCALER by using log method.
I am confused by your problem. If MTF-01 is the optical flow sensor you bought, some experts have already done the source code integration on both sides. We are just users, who follow the correct flight controller firmware to use and follow both the wiring and configuration. Then, focus the energy on getting the Application working with the sensor.
Where does your custom driver sit? Please elaborate more on your truth problem. What is the thing you wanted to achieve? Also, should you work on a companion computer “talking” to the flight controller unit instead?
