Hi Guys!
After reading many an many topics on the optical flow sensor on the APM 2.5, I decided yesterday to install it on my quadcopter APM2.5 firmware 3.1.5.
So I got an unsolved problem with it.
It look bad init when I power on my APM board.
How I install my sensor:
- cut the 5V track and solder the 3.3V track -> OK
- wire the NCS, MISO, MOSI, GND and +5V -> OK
- Adjust the focus lens with the python procedure -> OK (working very good)
- Enanbled the OPTFLOW on Mission planner -> OK
Now testing
on console mode:
test -> optflow
All the value are 0 and nevers change
on console mode:
setup -> optflow on
exit
test -> optflow
Yeah working good!
reboot of the APM2.5
test -> optflow
on console mode:
setup -> optflow on
exit
test -> optflow
Yeah working good!
again a reboot
test -> optflow
don’t work all value 0
I tried with beta firmware, old firmaware and on a another APM2.5 board… Same same.
OPTflow doesn’t work when a restard the apm board. (so the OPTflow still marked enabled)
Somebody get a greate solution? I’m the only one in this case?
Thanks for reading, bye bye
