OpenDroneTech - Raven A3 first flight
Dear Ardupilots,
Just did a first flight with a new design. I just wanted to post the log and param file for an extra pair of (expert) eyes on the initial result. Looking at RATE*OUT values and others. I’m using APD 40F3 with BdShot telemetry which is limited. I haven’t yet hooked up TEL to a serial port for more detailed telemetry.
Next up is manual, quik, and auto tuning.
T-Motor MN4116 340KV with Polymer 1704 props
CubeOrange FD
Ardupilot 4.6.3 BdShot
Linkage 18700 HV 6S 1950g
APD 40F3 ESC
Carbon and Titanum x-frame assembly
Aerodynamic water-tight fuselage
Since firmware update 2.3.2 the APD 40F3 now works with BdShot telemetry. I just added the more detailed telemetry also via SERIAL4 with PROTOCOL = 16 and Options = 0 and it worked like a charm. There’s some outdated documentation and info in threads out there stating that BdShot telemetry only works on the 80F3 but this is now working since 2.3.2
I also didn’t need any hassle with SERIAL options. I used GPS2 (SERIAL4) with GPS2_TYPE = 0 and I’m using 3840 on both BDMASK and MASK for SERVO_BLH
