I see the --upload for Linux based boards is no longer available. Is there a specific command needed or does sftp and/or scp work as intended?
I am attempting preliminary research before getting well. And by well, testing for SBus will take soldering and I would like to keep my binary from master…
if I can make a suggestion go straight to pocketbeagle 2, the only thing you will use with blue today is a rover - the copter and plane will demand a lot of effort and will work but with several limitations.
