Omnibus F4 Nano v6 Help with Frsky S.port
I am having no success getting sport passthrough to work with this controller. Only need GPS and sport to work. Have gps working but not sport passthrough. This is V6, not V6.1.
I have done this with pixhawk and pixracer with yaapu cable.
Anyone have this working? Thanks.
You need an adapter cable, f4 boards can’t do inverted serial that s.port uses.
Yes, I am aware that need the inverter. I still cannot get it to work. That’s why asking if someone actually has it working for Omnibus F4 Nano V6.
Thanks.
you need to give some more detail, what pads do you have the GPS and s.port telemetry connected to?
I just went over the flight controller and I think that might have a built in inverter for uart1 so you could skip the adapter.
I used Tx1 and Rx1.
Thanks.
this looks like it should connect directly
I would expect that could use inverter or not, depending on config.
I may try iNav to see if no hardware issues. If success, move to Ardupilot.
Thanks for the image.
your yaapu cable is just a serial inverter, your board has one built in so directly connect it as shown in the diagram.
I see that it might work with iNav. If indeed would work with ardupilot, No idea what the settings should be…
https://ardupilot.org/copter/docs/common-frsky-telemetry.html
