I’m trying to tune my small octaquad and I have some issue with Altitude hold function.
It is a 7 inch octaquad running at 4s with a flight time of 26 min. As you can see from log, it is a bit overpowered.
aircraft use an old VR Ubrain 5.1 running AC 4.0.7.
I recently enable notch filter and I think/hope I configured it correctly.
The issue is that in alt hold, it is not stable and move up and down for about 2-3m minimum and while moving forward I can hear motors increasing and decreasing quite rapidly.
The 1st thing to notice are these parameter values.
ATC_ACCEL_P_MAX,1800000
ATC_ACCEL_R_MAX,1800000
These are off by a factor of 10 so essentially it’s unlimited. Your filter values are too low for a 7" craft. Run the Mission Planner Plug-in from Alt>A and reconfigure.
hello there,
performed the Alt+A function and now copter looks a bit better. I got another strange issue. During translated flight or forward, quad is “vibrating” on the Z axis. It look like that throttle control is too aggressive.
Yeah, dropping PSC_ACCZ_P and then set PSC_ACCZ_I to 2x the value will stop the motor pulsing, I’ve not figured out how to increase the ALT hold strength Yet - seems my baro bounces about in MP (like most do)
