I would like to use an octa frame type “I”. I would like to arrange the frame with four motors in the front of the frame and four motors in the back like:
M1--------M2--------M3--------M4
M5--------M6--------M7--------M8
My questions are:
I see the code in AP_MotorsMatrix.cpp
case MOTOR_FRAME_TYPE_I:
add_motor_raw(AP_MOTORS_MOT_1, 0.333f, -1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CW, 1);
add_motor_raw(AP_MOTORS_MOT_2, -0.333f, 1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CW, 5);
add_motor_raw(AP_MOTORS_MOT_3, 1.0f, -1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CCW, 2);
add_motor_raw(AP_MOTORS_MOT_4, 0.333f, 1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CCW, 4);
add_motor_raw(AP_MOTORS_MOT_5, -0.333f, -1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CCW, 8);
add_motor_raw(AP_MOTORS_MOT_6, -1.0f, 1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CCW, 6);
add_motor_raw(AP_MOTORS_MOT_7, -1.0f, -1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CW, 7);
add_motor_raw(AP_MOTORS_MOT_8, 1.0f, 1.0f, AP_MOTORS_MATRIX_YAW_FACTOR_CW, 3);
break;
This frame type is supported, correct? And would I use number 15 for the parameter setting?
What number (on a Cube/Pixhawk 2.1) would I connect each motor to on the “Main Output” so that they are connected correctly? Or another way of asking - is there a diagram like the Octa H (https://ardupilot.org/copter/_images/motororder-octo-h-2d.png) for the I frame type?
If I am reading the code from AP_MotorsMatrix.cpp correctly, the motor layout for the “I” frame would be:
(Front of the Aircraft) #7CW, #5CCW, #1CW, #3CCW
#6CCW, #2CW, #4CCW, #8CW
(Back of the aircraft)
And the test motor sequence would go A=1,B=3,C=8,D=4,E=2,F=6,G=7,H=5
Sir I’m sorry to , my experiment is still running because I can do that , but my were house (when I trying my all experiment) it’s close down because corona virus and all are still support stay in house.
So , may-be tomorrow early morning I will do that and I will give you my notes.
Thank you
