hello
i am using pix4,raspberrypi3
i would like to make a autonomous drone using raspberry pi and pix4 with ultrasonic sensor only front side
so i need to integrate obstacle avoidance in guided mode using BendyRuler
could anyone tell me how to make it…
i tried reading the docs below
https://ardupilot.org/copter/docs/common-oa-bendyruler.html
but i cannot make it
my raspberry pi code below
import time
from dronekit import connect, VehicleMode, LocationGlobalRelative
import math
import RPi.GPIO as GPIO
from threading import Thread
import time
latt = "17.xxxxx"
long = "78.xxxxx"
alt = "1.5"
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
TRIG = 4 # Trigger pin of the Ultrasonic Sensor
ECHO = 17 #Echo pin of the Ultrasonic Sensor
GPIO.setup(TRIG,GPIO.OUT)
GPIO.setup(ECHO,GPIO.IN)
connection_string = "/dev/ttyAMA0"#args.connect
# Connect to the Vehicle
print('Connecting to vehicle on: %s' % connection_string)
vehicle = connect(connection_string, wait_ready=True, baud=921600)
vehicle.wait_ready(True, raise_exception=False)
#Connects to the vehicle using serial po
def sensor_data(d,o):
msg = vehicle.message_factory.distance_sensor_encode(
0, # time since system boot
5, # min distance cm
300, # max distance cm
int(d), # current distance, must be int
0, # type = laser?
0, # onboard id, not used
int(o), #direction
0 # covariance, not used
print(msg)
vehicle.send_mavlink(msg) #Simple function to measure the distance
point1 = LocationGlobalRelative(float(latt),float(long), float(alt))
vehicle.simple_goto(point1)
def measure():
dist1=250
GPIO.output(TRIG, True)
time.sleep(0.00001)
GPIO.output(TRIG, False)
echo_state=0
while echo_state == 0:
echo_state = GPIO.input(ECHO)
pulse_start = time.time()
while GPIO.input(ECHO)==1:
pulse_end = time.time()
pulse_duration = pulse_end - pulse_start
distance = pulse_duration * 17150
distance = round(distance, 2)
if vehicle.location.global_relative_frame.alt >= 1.2:
if(distance<250 and distance>5): #To filter out junk values
print(distance)
dist1=distance
sensor_data(dist1,4) #Sends measured distance(dist1) and orientation(0) as a mavlink message.
else:
dist1 = 0
return dist1 # Main code
def objstart():
while True:
measure()
time.sleep(0.2)
vehicle.airspeed = 5
vehicle.groundspeed = 50
vehicle.parameters['LAND_SPEED'] = 25 ##Descent speed of 30cm/s
vehicle.parameters["WPNAV_SPEED"]=150
vehicle.parameters["PRX_TYPE"]=4
vehicle.parameters["OA_TYPE"]=2
vehicle.parameters["OA_BR_TYPE"]=1
# vehicle.parameters["OA_LOOKAHEAD"]=2
# time.sleep(50)
vehicle.parameters["OA_DB_EXPIRE"]=10
vehicle.parameters["OA_DB_QUEUE_SIZE"]=100
vehicle.parameters["OA_DB_OUTPUT"]=1
def arm_and_takeoff(aTargetAltitude):
print("Arming motors")
# Copter should arm in GUIDED mode
vehicle.mode = VehicleMode("GUIDED")
vehicle.armed = True
# Confirm vehicle armed before attempting to take off
while not vehicle.armed:
print(" Waiting for arming...")
time.sleep(1)
print("Taking off!")
vehicle.simple_takeoff(float(aTargetAltitude)) # Take off to target altitude
while True:
print(" Altitude: ", vehicle.location.global_relative_frame.alt)
# Break and return from function just below target altitude.
if vehicle.location.global_relative_frame.alt >= float(aTargetAltitude) * 0.95:
print("Reached target altitude")
break
time.sleep(1)
print(vehicle.battery.voltage)
arm_and_takeoff(alt)
print("Take off complete")
Thread(target = objstart).start()
# Hover for 10 seconds
time.sleep(3)
print("Vehicle going to the location")
the vehicle.message_factory.distance_sensor_encode
output can be seen in mission planner inspector window but no response in proximity window
